Wtb 17 inch rims suit 4 stud (4x100) in decent ish condition, can vary, without tyres preferably unless it has 205/40/17's
for a nissan nx-r as its now my new daily driver. Pm me with details or txt - 0422360999
not looking to spend to much (couple of hundred)
Free or cheap as chips , rb25det NEO r34 alternator not r33 not the same config
Gtr r34 alternator would work too
Can be dead or alive and needs pulley still
Must have a unbroken case
Its for a project to benefit sau in the long run
Pm me
Cheers
also after some 235/40/18 tyres (prefer as much tred as possible)
cheers all
Urgently Wanting To Buy: R33 series one front bumper, MAYBE reo bar if i cant straighten mine out.
Can be any colour (although my car is black), stock or bodykit, as long as its good condition.
My brakes failed and ive stuffed up my front end and need one asap so i can get to work.
Reply via here, or more preferably via my mobile 0401 031 323 Much appreciated :)
Bumper has been purchased.
I now urgently need a r33 series one front bar reo. cheapest ive seen so far is 180 from a wreckers, so if you can beat that and you contact me on my number provided above before 5pm today you have yourself a sale :)
WTB:
S13 / R32 on front seats with rails (pair). Fabric doesnt have to be in the best condition, as long as they have rails complete, the slide mechanism works and seat structure itself is fine
For a friend's project car
Contact via PM
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
