I'm am chasing the following parts all to suit a r33 GTR must all be genuine...
-drivers guard
-drives skid skirt
-drivers rear pod
-drivers door trim
-drivers rear qtr trim (door trim thing)
-front bar
-drivers headlight
-white GTR grill with badge
Call or txt me 0431 391 262 with prices
Would like to source most parts by next weekend so just trying hear before I go looking at the wreckers.
