Urgent ...
Need that little hose behind the head/lower plenum, which connects from the lower intake plenum to the hard pipe which goes to the turbo around the back of the head. Its a little coolant elbow rubber hose.
Please PM me or call 0449 928 227 if you have one.
:thumbsup:
WTB - V35 18" wheels, premium spec, like these ones that someone had for sale on here a little while ago, i missed out.
http://www.skylinesa...ims-with-tyres/
If you have any that you'd like to part with, let me know via PM
Also chasing an RB25 clutch fan assembly including viscous centre.
Edited by Sorin-Andrei
WTB CAS Sensor R34 GTT. According to the web, its model 23731-5L30A which fits:
Nissan Skyline R33 GTS25 (RB25DE) / GTS25-t (RB25DET) / GTS-4 (RB25DE)
Nissan Skyline R34 GT (RB20DE Neo 6) / 25GT (RB25DE Neo 6) / 25GT-4 (RB25DE Neo 6) / 25GT-t (RB25DET Neo 6) / GTR (RB26DETT)
Tried to go down to JIS this afternoon, but despite their website saying closing time at 3pm, turned up a little after 2pm and closed up.
Hi guys, had some work done on car, looking to upgrade ECU from the stock rb25det one, mine is an Auto Coupe'! been looking seriously at getting NISTUNE :D does anyone have a nistune board to suit even if its in the Z/R32 ecu as long as its all prepped for auto R33 :-)
definitely the next addition to my car I believe to make a difference in the overall drivability/power/acceleration etc of the car to get this nistune and get a proper tune done :)
thanks guys if any1 has one to sell or can suggest a good place to get one?
CHEERS
MIKE
CHEERS
MIKE
Best bet is to find the best ecu for the application in the second hand parts thread (I see them all the time) and then see Pete from PLMS for a cable,nistune board + installation - he'll take care of you
Got mine around 2 years ago, was a great investment
-D
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
