Well, I need new front rotors for my skyline - R33 GT-R vspec, what are the best rotors (or best compromise between rotors and price). Will hopefully be seeing more track time soon. I was looking at the DBA rotors but after reading a thread on them here have gone off them a bit. Also what pads should I be looking at getting?
Thankyou
https://www.sau.com.au/forums/topic/143995-what-are-the-best-rotors-and-pads/
Best rotors and pads I've used? Project Mu. But you'll pay for them.
I am quite fond of Ferodo DS2500 pads. They work well enough when cold, but will handle some heavy abuse.
Not sure about a bang-for-buck rotor, though. I've used DBA slotted and cracked them, and I know guys who've cracked 4000s and 5000s. They are the biggest name in Australia for rotors, though.
I agree with scathing. Project mu all the way but at $1100 or so retail for a set of 2 piece front rotors it's worth checking your options.
I'm fairly certain DBA do a 2 piece rotor to suit the brembos though. It may be a cheaper option.
I've had DBA5000 with my Brembos and they worked well on the road, but warped under the hi temp stresses of competition with quick hot-cold cycles.
Get a price on some two piece Alcons or Harrops if you want something really good, but DBA5000 would be fine for most work including having a crack every now and then.
Thankyou
--Thanks for the info all, looks like I won't be buying something 'really good' just yet!. Now looking for a set of cheaper standard or aftermarket rotors to get me through for a while if anyone has anything available.
Thanks again.
I have the G4 brakes and they work ok on the street, still waiting for the next track day to give them a real work out.
I used the RDA rotors before and they were fine for some time but lasted about 8 track days before cracking , but i think the level 900 project Mu pads were a bit on the hi temp side with these discs
I have the 356mm rotors. Had the old girl out for a spirited run last night as i have about 200kms on the new brakes now and i have to say they do work well under a spirited road drive which is still some way off a track day session but they do pull you up. And they still have lots of feed back through the brake pedal so all in all i am really happy with them so far. May have a track session on friday night under lights so i will give you some feed back then.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
