Hey all,
Thought you would like to see some pics of the red bull air race from last weekend :D. It was great to be there and what was even better was getting home after the event to see the delayed telecast on TV to give you a pilots view of the manoeuvres! :wave:
As you can see it is a bit difficult capturing the action with a compact camera (really could’ve used a zoom lens!) but some of them turned out ok. Check out the to_drift one…..that plane was taking off with a cross wind and got so sideways that it was pointing its nose at me standing beside the runway while trying to fly straight :dry: !!
Enjoy,
Ant.
post-6243-1164073086.jpg post-6243-1164073095.jpg post-6243-1164073105.jpg post-6243-1164073113.jpg
post-6243-1164073121.jpg post-6243-1164073128.jpg post-6243-1164073136.jpg post-6243-1164073146.jpg
post-6243-1164073154.jpg post-6243-1164073164.jpg post-6243-1164073172.jpg post-6243-1164073180.jpg
post-6243-1164073196.jpg post-6243-1164073206.jpg post-6243-1164073220.jpg post-6243-1164073229.jpg
post-6243-1164073238.jpg post-6243-1164073248.jpg post-6243-1164073257.jpg post-6243-1164073266.jpg
https://www.sau.com.au/forums/topic/144108-pics-from-red-bull-air-race/
That red bull helicopter really hauled ass. The air race was cool but the highlight for me was definately the f/a-18. That thing was soo damn grunty, some guy said something about it having more power than all cars in an f1 race combined.
I got real drunk and real burnt in the sun, its was sweet :wave:
Hmm the "great pics" i took turned out to be not so great. Got some vids but cause of no zoom you really cant see much.
Thanks for the comments guys. Tell me about it boosty....my compact digi has a 5x optical zoom and the above pics were taken with the max zoom....even then they come out pretty small :)
Time to invest in a SLR me thinks :woot:
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
