Hey guys just wanted to ask some advice. I park my car on a slight incline, so that the front is higher than the back of the car. Every time I start it in the morning, after a few seconds, there's a horrible screeching sound coming from the engine, then the screech stops, and the revs increase a little then settle down after about a second to the normal rev range for idle. I'm not quite sure what this was, i thought it was low power steering fluid or something so I topped that up, but now that that's ok I'm not sure, because if I drive off too soon, the moving off process causes some slight screeches too...thanks in advance :huh:
https://www.sau.com.au/forums/topic/144425-start-up-screeeeeeeech/
Sounds like a belt is a bit loose and when it sits it slides toward the back of the car and rubs up against something. Which belt is the scary part! Could be simple, A/C, Power steering or Alternator... or SCARY, Timing belt.
Get a Mechanic to check asap, or look yourself... but I'd say from what you've said you wouldn't know if the belt was too loose or too tight. So go the Mech :huh:
Get a Mechanic to check asap, or look yourself... but I'd say from what you've said you wouldn't know if the belt was too loose or too tight. So go the Mech :P
haha yeah you guessed right..I wouldn't know :huh: might wait to see what other ideas pop up then go ee him with a better picture
i'd say its just a belt slipping. and what is happeneing is that it is spinning for a second, then it heats up a bit and gets sticky and grips and gets on its merry way. very common problem amoung any type of car.
just go round and tighten all 3 belts slightly.
i hear that screaching noise every few months , i mainly notice it when we get some rain or a misty night , my opinion is it could be moisture getting to the belts? my opinion - im not a mechanic or anything , but i do notice it in those conditions . on my old car i got the same noise and sprayed some wd40 on them , would stop the noise , from happening in winter
Just a quick question (may be dumb lol) but how would i go about "tightening" the belts, i thought when they got worn out and started slipping you just had to replace them, can you extend the life of them?? Thanks heaps :(
Regards,
Sean
I'd replace them, but I'm picky :)
First you'll need to identify which belt is lose, they all have a little bit of slack... but you'll notice if one has more then the others.
Then find the tensioner/pulley that is on a sliding hole (when you loosen the bolt it can slide along that hole). Then just slide it until it's reasonably tight. It's not a big deal, but just remember to be careful and don't make it too tight as to stretch/damage the belt.
Wet some soap untill it becomes like Jelly then apply to the belt.
PRESTO......no noise.
That may stop the noise, but wouldn't it encourage more slipping?
Soap acts as a lubricant, especially when moisture is added.
If you want to be that dodgy, you'd be better off pouring coke on the belts.
The fix for you...did this last week on my Maxima.
Cheers
:sick:
Damn, that sounds like a good fix, might try it in a min :wave:
thanks for all the replies guys :spank:
When the soap dries it ends up being a dry lube.
Coke :spank: .....is only when u use Bourban......
Dodgy you say.....my mechanic recommended it.
Angry Fist.........Post up your results after you have lathered up. :sick:
The thing is you dont want to lubricate anything here. Belts arent supposed to slip.
Another cause for a slipping belt if its not just slack is it can be bottoming out in the pulley. Like i said b4 check for correct belt tension and signs of slip and replace or tighten as necessary
I recently had a loose fan belt that made the same noise until the alternator regulated output to 14V, then it would stop.
Tightened a smidge and it's good as gold. 5mm just like Deren suggested.
PS Using the soap is a good way to help identify which belt is causing the noise. Washing up liquid works ok as well. It saves replacing belts left right and centre.
Tighten it up, or as someone sujested soap as a quick fix to the annoying squeek.
I'd sujest dr y soap, just take a cake of the old "sunlight" yellow shit, and why yoru cars running put it on teh belt :) I did it when mym was winging about her commodore squeeking, and becuase i coudlnt' give two f**ks about that car i soaped it up :) when i took my alternator of for re-conditioning i didn't do it up tight enough so mine did the same, but i stayed away from teh skyline with the sunlight soap, i just tightened it up :)
Same happened to me yesterday - put your hand on the pullys of the ALt and Steering pump etc when MOTOR OFF and you will soon feel which pully is slipping from the temp, near burnt my hand on Alt pully. Sure enough belt a bit loose but not imeadiately obvious.
I loosened it right off first to check it was not the bearings though, then tiightened up.
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
