Group Buy # 3 Arospeed Adjustable Cam Gears, By Popular Demand
  • Replies 240
Posted Images
So whats the go?? when are the gears going to be shipped?
Made payment on monday takes 3-4 working days for money to clear then my supplier advises me on approx arrival time, ill advise soon as i hear.
Any update since money was transferred last Mon?
Good new's i recieved email from US supplier, cam gears will be leaving on the 17th Jan from the US.
Edited by r33kid
yep on there way usually take about 4-7 days, so should have them here soon.
Soon as they land ill post up here and start to despatch.
Once again thanks to all.
Is the inlet cam gear *exactly* the same as the exhaust cam gear?
If it is, does anyone want to buy a gear?
I've put my name down for a pair of gears, but after doing more researching and buying a powerfc which will control timing on the inlet side, i think i only need to adjust the exhaust side to get some extra K W 's. Is this right???
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
