SERIES 2 1996 R33 SKYLINE
ENGINE: 356 rwkw @ 1.5bar
-RB27DET-
Just clocked 50,000 original K's, done much much less since re-build
N1 bottom end - nismo
N1 RB26 crank - nismo
N1 RB26 oversized forged pistons - nismo
N1 RB26 conrods - nismo
RB26 waterpump
Tomei Adj Cam (inlet)
HKS Adj Cam (exhaust)
HKS step 2 cams 256 deg
Trust Timing Belt
Apexi RX-6 turbo
Custom Manifold
50mm Apexi external gate and screamer
Greddy type r BOV (race spring)
Greddy Plenum
800cc injectors
Q45 infiniti throttle body 90mm
Custom intercooler 650x300x140mm
Custom radiator
Custom oil cooler
3inch piping to turbo and inlet
ENGINE MANAGEMENT:
HKS F-con Vpro
Garage AQUA ECU
fully tuned in japan by GARAGE AQUA
HKS Boost Controller
HKS Turbo Timer
HKS gauges - oil temp, water temp, boost, exhaust temp
SUSPENSION:
Crux coilovers
S.W.I.F.T springs 14kg front, 12kg rear
IKEYA FORMULA lower control arms (brand new)
IKEYA FORMULA castor rods (brand new)
GTR rear strut brace
Cusco front strut brace
FUEL SYSTEM
full external fuel system running to an internal fuel tank
650hp rated external fuel pump
5ltr swirl pot
OTHER GOODIES
R33 GTR Brembo Brakes all round - ENDLESS CIRCUIT PADS
Braided Brake Lines
Tomei Brake Booster Stopper
Exedy Twin Plate Clutch
2-Way LSD
Short Shift Kit
30mm front spacers
40mm rear spacers
awesome widebody
30mm rear pumped over fenders
25mm front fenders
BN rear bar
BN side skirts
Trust/Gracer front bar
Drift-R rims
18x10 +24 rear
18x9 +24 front
complete new headlight set up
angel eyes as well
VELO APEX race seat
Hydraulic e-brake + normal e-brake
8 point cage
Fire Extinguisher
Serious people only, i dont appreciate people wasting my time, any serious offers please pm me, but any prices you think its worth please let me know
May have forgotten stuff, theres a fair bit
Edited by Nathan_G1
https://www.sau.com.au/forums/topic/144770-r33-series-2-widebody/
i am also willing to swap for something + cash, unless that something is of reasonable equal value.
this is just a way to extend the target market........read the list, there is practically nothing left to do on this vehicle
25k is what im after, or a swap deal.
this car is not a 25t its a 27t and is amazingly set-up, your crazy not to take a car like this, the engine alone is worth around 25k, your just getting the shell and other gear thrown in
graph sheets around somewhere, because its RB27 and has the RX-6 turbo, it actually has minimal lag, drifitng it came on boost around 3200-3600, its amazing, the torque response is phenominal even before boost
dyno was with a 20:1 ratio of pump and toluene, so about 2 ltrs total of toluene everytime i drove it........very carefully mixed up.
however, my plan was to get it re-tuned with can fuel like elf 110 octane perhaps.
car is awesome man........its a treat, never have i been anything as fast or powerful
first dyno pull in Aust Jap tune pump fuel
we found a few Japanese track entry slips in the glove box unfort no time slips he he
car was driven at 1 bar made 490ps in Japan
Edited by 1400r
Um so the car recorded 355rwkw 1.55bar at a SA SAU organised dyno day a month or so later with many SAU members present for its run
all this on a dyno that a number of cars recorded lower figures than normal at
my boss wanted more boost to be screwed in but this never occured for some reason
as you can clearly see from that run there is way to much fuel for max power in the top end
not sure how much a retune would gain but I'd say there a bit more in it
the new owner Nathan above was given the 355rwkw print out I only had the tilbrooks lower fig
the great selling point of this package is the fact it has very little lag for the power it makes and the way it revs hard
3lt's ftl
I think I see the green eyed monster simple to solve mate buy it pull the motor out stick it in your car
Edited by 1400r
N1 bottom end
N1 RB26 crank
Just a question...
Looking on yahoo the N1 pistons are still cast...how do you get the extra 100cc from 20 or 40thou pistons?
Still the results speak volumes....good luck with the sale
pistons are listed as being 34gtr N1 1mm (I assume 1mm overbore)
got an idea on displacement Roy with 1mm oversize?
probably 2.601 he he still counts as a 2.7lt as auction sheet claims
also looks like the motor was rebuilt to these specs at 49,900km
Edited by 1400r
i was selling the shell.........now ive decided to sell the car - unless ur interested in the shell only.
will sell the shell with standard gear, no motor no box....none of the goodies, just shell, rims,kit, spacers, and standard other items
do u want the whole car or shell?
whole car i want 25k solid......shell 9500, car is uncomplied and cannot be its for race use only as ive mentioned in most posts....but something this sick you really dont want on the road and trust me when i say that
cheers
  • 3 weeks later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
