  • Replies 46
my box will look very similar to the one wogsrus posted, accept a little bit different at the back, and my afm is going to bolt to the box, and just have the adapter bolted on the inside of the box.
i think having the afm mounted to the box is a good idea since it is hard mounted in stock form, and so it doesn't rattle around and get damaged.
Has anyone gutted a standard airbox to put their pod filter in? I picked one up cheap but am of two minds as to whether I gut i for the pod filter or put a panel filter in it..
thought about it.. but theres no chance one will fit in there ....you could hang it out the bottom just to hide it from cops but it would b pretty crapp.
the template is easy to make. just get some thick carboard, a pen and either scissors or a knife and just keep trimming untill you get the desired shape. take about 5 mins. i think the template is just a touch bigger than an A4 bit of paper, otherwise i would scan it so people could print it.
i think i still have the plans for that design listed above from another member a long time ago, and its actually not to bad.
Im currently redesigning my new airbox, as my other design works really well with stock cooler piping ,but with an aftermarket cooler and i can no longer use the snorkal.
My new one will still consist of 3 side walls and a lid that screws on and off for easy access to the pod, and it will have a direct feed from the front bar to the exisiting hole under the pod where the old cooler use to sit.
The inside of the air box will either be from firewall foam, or i've been to clark rubber and they sell a foam/rubber insulation, so i will be testing all this out in the coming weeks and will post my results
on a side note i've also started to remade a coil pack cover with my number plate letters cut out and meshed out and put LED's under it to :huh:
RICER!!!! hehehe
i just had a thought (i know, i'm scared too). i think i might use clips to hold the lid on. the same sort of clips as what are used on bonnets. that way it is easier to get to the box.
were all counting on you now!
lol hope you make it b4 febuary!
license back in febuary! need an airbox so i dont get defected (again)
on a side note i've also started to remade a coil pack cover with my number plate letters cut out and meshed out and put LED's under it to :ninja:
well maybe this sunday i will try and build a new one :D
sounds like a great way to spend a sunday... hey you use g max rims right.? i lookin round for the website or ppl who sell em..
cant find squat..
havent picked up the fone yet tho.... :)
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
