Stereo install day
31 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Just throwing up an idea.
What if we had a stereo install day maybe in a Strathfield car park where you bring, or buy on the day, your uninstalled stereo gear and the people in the club with experience can help you install it?
We wouldn't be making any sub boxes for you but I think it would be fair to say that the main purpose of this is for the experienced people to help with wiring for those who know nothing or very little about car electrics and to show how things like the dash come apart and go back together for those who haven't delved that deep into their cars as yet.
We can also tune the system once it's up and running as well as explain along the way what things are and how they work.
https://www.sau.com.au/forums/topic/144908-stereo-install-day/
You're planning on doing this at a Strathfield car park? Don't think it'll go down too well.... it is part of their business you know.
Also; the soldering irons which plug in will be useless, you won't have readily accessible power. So you'll need a gas powered one.
Its a good idea in theory, but i dont know how well it would work, stezza installs do need a bit of concentration and explaining it to the unknowing user would take alot of time, so 3 people in the know how with stezzas, and 8 uninstalled systems would be a bit whack.........
Umm who said anything about Strathfield Car Radios.? :)
i'm pretty sure thats what adams saying
i thought the same thing before i re read it and it says "A strathfield carpark" rather than "THE strathfield car park" as if there were some car park where you usually do these things
could be wrong though
You provide the beer, ill provide the tech support, ill also need a lift....
"Lets see who can wire a stezza good after smashing a few beers day"
:happy:
pfft electrical tape, gaffa tape ftw, grip like no other
i've got 1 or 2 power converters. just plug into cigarette lighter and converts into 240v AC that i was using for the ps2 in my m3. but now ive got one laying around since its out now.
im not sure if we can hook up a few with extensions and a power board (with the car running ofcorse). its just an idea though.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
