That is something that i really was keen to know, as i figured ,from what the microtech is. that it probably wouldnt be that great for a daily driver, as some of you guys have pointed out. I mean my tuner is a pro at them, and has turned out some great high HP rides using them, but they are Yes " race or weekend" cars, which dont suit my profile.
Now to find myself a PFC for my 33. in good condition... ahhh. i can see im going to have fun.. Im in brisbane, and was going to take it to the P.I.T.S, anyone else know anywhere else that are just as good, for less $$$? for the PFC tune?..
maybe around brissy?.. thanks
  • Replies 43
there is NO better advice than what MR331307 gave you.
I dont see how it isnt what your looking for.
The ECU is ONLY as good as what the tuner can do with it
I'll third that.
I'm a great believer in asking for many opinions... but you won't be getting many tuners, so find your tuner first!
You're prices are a bit out. Currently I know of two LT12S's for sale under $1200 plug and play.
My tuner charges $300 for full tune.
Also, from experience in two different cars I've owned with microtech's... they were excellent on and off boost as every day drivers and people would always comment how smooth the engine felt as a passenger.
Those with bad microtech results have bad tuners.
If my tuner prefered PowerFC, I would have got one of those instead. Although I do like no AFM... don't know why...
I have tuned quite a few of both, and unless it has 1000hp and the afm is casing a restriction, the pfc has many more features than the microtec, and will return better fuel economy/cold start/drivability with far less tuning. Most dyno shops can tune a pfc, and many have datalogit, if they cant, i wouldnt let them tune my car.
The problem with getting poor economy,Bad cold starts,Driveablity problems is to do with poor tuning
ive got microtechs in alot of EVERYDAY DRIVEN STREET CARS
and they seem to start straight away no problems and still get 400 kms out of a tank making around 400 rwhp
my advice is to tune more into them or DO THE MICROTECH TECH cause to learn about them
The only problem with microtechs is that too many people think they know what they are doing with them but they dont
Have everyone played with wide open throttle maps and cruise maps
ive had customers from other shops walk into mine saying i wanna change ecus cause the microtechs shit bla bla bla
i get it on my dyno and tune it and the customer comes back in a week with a smile on his face.
Whoever has a microtech and has anyproblems just tell your tuner to do more tuning on it.They are the way to go
A AFM ecu and a map ecu can have the same fuel economy and tuning points but i choose the map sensor cause i can accuatly tune invidual boost rpm points
and also the microtech plug n play installed and tuned is around $1600
if you pay more then this you are getting overcharged
Edited by MR331307
With a very simple closed loop, and far less resolution on the injector duty cycle, trying to get accurate mixture control is impossible with big injectors, especially at low rpm, which has to effect fuel economy.
maybe if your runing 1600cc injectors
we have vls running 1000cc injectors getting around 300 kms of Normal driving
and besides that
any car with injectors bigger then 850 cc isnt really great with emissions
if you are needing any injector more then 850 cc id perfer to run motec,haltech,hydra or autronic anyways
Thanks for that LNEMUP, I was really starting to wonder why the LT's had such a bad rap, everyone who asks about mine has a wonderous look when I tell them my economy. BTW my tuner is Peter Woodward.
mate i stand by them all the way
next year im running the lt16 for my r33
speaking to john about it
honestly all ecus are the same once you have some good at tuning them all
but the microtech is the far easiest and cheapest to run once you know what ur doing
I've had my R33 for 2.5 years now. It runs an LT12 "plug and play" and it's used as a daily driver.
I completely agree, the Microtech is fine for everyday use, but I had a separate map set-up for economy. Original "mild" map was a bit rough and it showed by only returning an average of 17.0 - 18.0L/100Km in city driving with only 189rwkw! On the other hand, my new "economy" map is averaging between 13.5 - 14.0L/100Km in the city with a still healthy 165rwkw. With fuel prices the way they are, that's more like it! ;o)
Each state would have its share of "gun" Microtech tuners, but only a select few are "the real deal".
Query the forums and ask advice from people in your state who have had good results from their Microtech guys, don't bother experimenting. For example, here in Adelaide, I've could only recommend two guys that I would REALLY trust my Microtech with.
There are alot of Microtech experts around but I would reluctantly say that most are specialised in Rotaries, not Nissans. And I've tried tuners that the Rotary guys rave about but they could not extract any worthwhile results from my RB.
Had I been buying one now, I could safely say that I would be happy with either. There have been a few horror stories around, but they are more a reflection on the tuner, not the ECU.
The Microtech and the PFC both have their individual strengths and weaknesses but overall, they're both great ECU's with strong support networks. Put it this way, you could do ALOT worse!!
Good luck with your decison.
It sounds like from what has been said that the microtech lt12 has more resolution for injectors and can be tuned for fuel economy well. I may take the microtech tuning course now that I know there is one. The self tuning capability was the reason I bought it in the first place, and the fact laptop software came bundled with it.
recently I had manual conversion and it was simple load tuned with autobox before conversion to manual as it is now. Has not yet been tuned for manual with flat spots evident, getting over 400-420km/tank running somewhere between 14-18 psi standard turbo variable due to the silly bleed valve.
I think with a proper tune this could work out with amazing fuel economy.
MY QUESTIONS
Is the visible knock sensor on power fc really helpful in tuning the car, or is air/fuel ratio using wideband sensor with the microtech a better way to go?
Can you tune off boost low throttle for 14.7:1 or even 16:1 fuel ratio using the microtech the same as with power fc as I've been told?
When the microtech sees 0 boost does the tune utilise rpm to determine assumed air flow?
Can the microtech self tune?
What is matrix tune?
You should use a wideband sensor when tuning your car anytime.
I was told the knock sensors in power fc's or safc2's aren't that flash and an experienced tuner shouldn't need them.
Microtech does take TPS input so low throttle or hi throttle or whatever is just the same as powerFC.
Microtech see's vacuum as well as boost, so there are no problems when you are seeing less than 0, if thats what you are asking.
No it doesn't self tune, unless there has been an advancement I am unaware of. At the same time, autronic self tune is not recommended as the only tuning, so self tunes seem to just keep things in check after a proper tune.
I think all the little things, like 'self tune' and 'knock sensors' etc, are kinda little gimmicks which aren't important if you are after a decent tune to help your engine run as well as possible.
All ECU's can be tuned to give better or worse economy.
I think you are seeing the computers as more different than they are. The main difference is one takes Air Flow input from your AFM's, the other takes MAP input.
Because all stand alone ecu's do pretty much the same thing, you'll find the best advice is as earlier stated... go with what your tuner wants to tune, because its the man ( or woman ) not the machine that will make a good tune!
the powerfc and safc dont have their own knock sensors, they use the cars factory one and simply display it to the use in a meningful value. i watch my sensor every day and it provide useful feedback on engine detonation. i use this to make an informed decision about load and ignition timing. they can be used for ign timing tuning and are quiet effective. they are not a replacement for a wideband sensor, and never meant to be. without knock sensor display the user would be unaware of engine deontation when driving. so the engine could be pinging and there would be no alerts, other than audible detonation
steer clear of microwreck IMO
i have seen un explained lean outs with microtec causing blow ups (several)
since changed to motec problem solved stable A/F ratio
all bad tuners make excuses
ITS CALLED WOT MAP
in RPM %%%%%%`s
Edited by MR331307
well i guess ive gone about this backwards, i will soon have a pfc and i dont have a *tuner* lined up, ive rang around for some rough idea on full tune cost and get anywhere from $600-$900, any suggestions for a tuner todo mine, im in sydney? p.s i chose the pfc because im abit of a sheep lol. if hundreds of ppl swear by em and use them on here and not many other rcu's get mentioned then it must be good.
Edited by dead32
take it to adam at just engine management for power fc
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
