Works a treat!
Chirps 1->2 shifts on smooth concrete.
Much tighter gear changes. Hardly noticable slight clunks when taking it easy. Shifts are almost instant. Will keep you all posted how the shifts work when I take it to the strip, but definatly a worthwhile upgrade for the automatic transmission.
I did it at home on jack stands, pisses fluid all over the place and there are so many damn bolts holding in the valve body.
https://www.sau.com.au/forums/topic/145467-mv-automatics-shift-kit/
Works a treat!
Pictures?
:laugh: cheers :D
Mmmmmmm can you tell me how much one of these kits are, how quickly does it change? Standard takes about 3 secs doesnt it? PM me if you dont want to post it on here. I have auto R34 and would be interested in this upgrade one day??
Got a few videos, some are quite shakey but thats coz of you SK and you kit, and a few are shakey on gear changes....thanks MV :)
Some are WOT, some are normal driving. Obviously the revving in the background will tell you what is what :ninja:
http://www.youtube.com/watch?v=IEBcaneDUZg
No offence to the guys with Skylines posting up in this thread, but I made the thread in the Stagea section for two particular reasons. We have heavy cars and we have 4wd cars. For this reason, I wouldnt compare the performance of a shift kit on a skyline to one on a Stagea.. sorry if that sounds rude but you understand I'm sure.
Comparing the shifts to the stock one is not possible. The stock shifts are just so damn slow, mine used to rev freely for about 1-2 seconds before it grabbed 2nd. Now as you can see in the videos its almost instant. I HIGHLY reccomend the upgrade to anyone with a Stagea.
The chirpies are coming from the front wheels too, not the rear.
Cost was $440 delivered including a service kit (new sump gasket and filter). The VB was 350, shipping 30, service kit 30 and GST on top (Yes, shifty bugger qouting GST free)......definatly worth it though. Honestly.
As far as the install, I will do a write up next week for everyone, the instructions that Mike gave were borderline, but I managed to guess it through :laugh:
I also find the auto goes through gears a HEAP more. Its always going between 3rd and fourth now, and its really quick too. I find it locks the converter up more easily now too. I can get lock up at 60kph and push just a slight bit of boost (around 0psi-1psi). Kick downs improved a lot and the throttle response from the gearbox has improved greatly too. I plant my foot, off i go. No more, plant, slip, slip, slip, kinda grab, go.
The job took me 4h, that was ciggie breaks, scratching my head breaks, waiting for my mate to come around mid way through breaks etc.
I could now do it in about 2-2.5h flat out. Maybe even less. DEFINATLY less with a hoist :woot:
Nice effort Alex. Loving the S1.5 youve got there mate.
Yeah my mech mate Ryan who did my turbo last week has done a few MV shift kits, like you mentioned the fluids goes everywhere when opening it up for the first time - hope you didnt catch tooo much of it in ya hair!
I was going to dismiss the MV valve body upgrade and not be bothered, but this thread may have changed my thoughts.
Meh, oil cooler and filter relocation kit is next job on the cards, then perhaps the shift kit.
edit: wow - no "flare" of the rpm when WOT. nice.
I was one of the benchwarmers watching alex fitting the kit. I have never seen so many f**king bolts holding together something, EVER!! The Nissans autos are vastly different from the Toyotas!!
Goes very well with the shift kit, very positive shift.
Alex do a ECU reset when its a bit cooler then take it for a boot! Itll chirp even harder!
Very nice mate,
Now how long will the box last??? I hope it does because I would like shifts like that in mine...
(Haven't forgotten about you either, will get back to you tomorrow)
Cheers
Luke
I've also got the MV automatics shift kit installed in my s2 stagea so it also has tiptronic, which is greatly improved.
Being in SA I actually got it installed AT MV automatics. Cost me $440 and that includes a transmission service - which normally costs around $150 for a quality service. So for the money it is very good value.
It still drives very very smooth if you want to, or will slam into gear if you push it hard.
The difference from stock is pretty easy to imagine. When you go to kick back a gear you put your foot down to the floor. Then there is a short delay while the gearbox ecu works out what gear you want, and then bang, you're instantly in the gear. I'd guess that the delay is about 1/2 a second or less.
Its not the same as a manual by any means but sure is a lot better than the stock auto. The main thing is that its not at all rough and you basically only feel a clunk if you change gears at high revs...
As far as how long the box will last, I was told that this upgrade actually strengthens the gearbox... :woot:
no chirpies for me though... :(
Edited by pixel8r
would you need one of these in a tiptronic? my guess is yes?
it makes the gearchanges much quicker and snappier. :)
and when just cruising around I can slightly feel the 1st to 2nd gearchange but the later gearchanges are smooth enough to be unnoticeable. :)
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
