is it like a metel clicking noise? quite sharp? moslty happens when coming on power or doing a sharp slow turn? .. i seem to have a noise from the diff area like that. have always been there so i havent thought much about it. its been over a year now so i shouldnt think it is much of a problem if at all
  • 1 month later...
  • 1 month later...
LOL...so noone has worked this out yet? I have had my car since 1999 and i cant work it out.
Im getting a new diff installed at the moment and quite frankly the noise is shitting me to tears after so many years.
I have had several ppl check it out and noone can work it out. Its not the handbrake shoes...and that was the most promising guess
This would be funny if it didn`t sh%t me so much.Worn uni-joints? Subframe bushes? Just guessing. And yes it is embarrassing when I take off or excellerate. I just tell people it`s a mechanical diff. :D
If it happens all the time when ur in gear then its most likely ur diff,
If it happens when on/off throttle or during engage then it could be the CV joints.
PLZ EVERY1, check that ur wheel nuts are done up tight. I had the exact same symptoms 2 months ago and it was becoz of loose wheel nuts, so check this first!
I got the same problem... been there since I bought it a year ago.
Mine only does it when you reverse then go forward. Only comes from rear right wheel.
Same here, my GTT does the same thing. However it also does it every now and then from a stopped position and moving forward slowly.
Mine has been getting progessively easier to reproduce the sound. Its quite annoying, doesnt affect the car in any way, but when you know its there its annoys you.
Got a few places to check it out, one place thinks its either a shaft or diff issue.
Please if anyone solves this let us all know!
*topic subscribed*
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
