Well with the wii you have two options
composite - blurry
component - jaggy
Wii isn't capable of graphics like that seen on ps3 or 360. Please note that i am not saying the games are crap but that the graphics aren't that flashy, i know it's all about the gameplay.
  • Replies 99
Bought Tiger Woods 2007 yesterday. Great fun and more than enough modes to keep you busy for hours. Getting the hang of the Wii remote as the interface for this one is hard though. Could be just too much time spent playing Wii Sport Golf.
godfather: blackhand edition came out yesterday... looks pretty good... does anyone know if excitetruck is any good? whats the control scheme like?
Excite Truck is awesome, it's very over the top. Insane jumps and great sense of speed leave you feeling like you are just on the verge of losing control. It looks pretty good too (for a Wii game). I had lots of fun with that game and there's a fair bit of stuff to unlock. Multiplayer is a bit of a let down but, no online and only 2 player split screen (no other cars). I would recommend this game is at least worth a hire if you are unsure. Also if you don't like the widdly widdly cock rock sound track you can put your own songs in if you have an SD card too (but the widdly makes the game IMO!).
I've heard good things about Godfather:Blackhand Edition on the Wii as well, I'll give it a hire.
I liked GT Pro as well, thought the controls were good and didn't have any problems after you get used to it. I wasn't able to try it out with the wheel attachment but.
EXCITE TRUCK IS AWESOME!!!
What he just said x2!!!
If you have a wii you need to get excite truck!!!! I'm looking at getting godfather this week coming, I've heard its good! I'm still not finisheed zelda yet, I'm so lazy :happy:
Wii is good ! :)
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
