  • Replies 55
Well SK, I am sorry to say that you are terribly wrong, I speak from personal experience and salad here can back me up on it, since he helped me out putting the bushes on.
I can believe that you go around telling people that the whiteline bushes give as much negative camber as any other aftermarket arm, when we couldnt get even -2.3 degrees from them!!
People if you want decent negative camber, DO NOT get this bushes you WILL waste your money as I did.
Cheers
Ric
Hi Ric, I have measured the arms themselves (centee of bolt to centre of bolt), that is the ONLY real meaningful measurement. It is pretty useless comparing static camber from one car to another. Every car is different, plus ride height affects the static camber readings a lot on Skylines. Then you have the effect of caster on the static camber readings.
I will emphasise, if you need that much negative camber then you don't have enough antiroll. You are sticking a bandaid over the problem, much better to fix the real problem.
:D cheers :D
I am running the whiteline swaybars front and rear and also 10 and 8 coilovers so you tell me how I am sticking a bandaid over the problem.
Now what I want to know is if there is a Whiteline kit that comes with inner and outer offset bushes? because this one came only with outer.
Cheers
Ric
:) cheers :)
Cheers
Ric
Does it have a front strut brace? I iassume it does.
What size stabiliser bars? You should have a 27mm front and a 24 mm rear
What settings on the bars? Are you adjusting them for driver feel as well as tyre temperatures?
What shocks?
What settings on the shocks? You should have lots of low velocity bump wound in.
What caster settings? Remember you are using opposite lock, hence introducing positive camber on counter steering to what is effectively the outside wheel. Too much caster means you are removing negative camber whenever you apply opposite lock.
Are you still running the standard rubber inner bush on the front lower control arm? If so, you are loosing dynamic camber when the bush contracts away from the counter steered outside wheel.
There is no "retail" Whiteline kit for R32's that comes with both inner and outer adjustable bushes. But lots of guys have been using 2 kits for several years, myself included. I am currently working on having Whiteline issue a 2 new "competition" kits for R32's. The first kit has 2 sets of adjustable bushes and no non adjustable bushes. The second kit is for guys who already have an adjustable kit and need more adjustment (ie; it deletes the non adjustable bushes from the current kit). Testing at the moment and I expect release early in the new year.
As I said previously, throwing more and more static negative camber at it is a band aid, you need to work on increasing the anti roll and fixing the dynamic camber change. Then you won't have to use so much negative camber, which means it will respond better on turn in, hold it's line easier and be more effective under brakes due to the increase tyre contact patch.
:P cheers :)
I can only get 0.5 and 1.5 on my front end.
Is it possible to use two sets of bushes to get more camber?
R32 front upper control arms ("I" shaped) are different to R33/R34's front upper controla arms ("Y" shaped). Plus R33/34's have different sized bushes in the front and rear inner mounts of the "Y" and they are both different to the outer bush. R32''s have the same sized bushes in the inner and outer mounts.
As posted above I am working on the R32, nearly finished testing in fact. But I haven't even started on the R33/34. It is next on the agenda and I will need an R34 victim, sorry tester (that's you). Obviously I will test it on our R33.
:P cheers :)
Yes I have strut brace front and rear as well.
The swaybars are F27 R24 thats correct, I have them set to soft on the front hard at the rear.
Coilovers are ISC F10 R8, mid to soft settings in damper for the front, full hard for the back.
Caster is 6.5 degrees both sides, toe -0.01 both sides.
I will check to see if the lower arm has the factory rubber bushes. I assume they would be the rubber ones since I havent change them, unless someone did it previously in japan.
I would hope that the "second kit" will be a lot cheaper, than the normal kit since its only half of it. Hopefully is not too far away to get those kits so I can get that little extra adjustment that I need.
Cheers
Ric
When people say I run to much camber on the front I tell them to look at the V8 supercars. They use big neg camber on the front, so it must be good for turning at high speeds. Im sure they would have big sway bars too. So neg camber on the front is not a bandaid cure by anymeans.
V8 Supercars run a tyre using completely different construction. They dont use wishbone front ends...plus they actually have the shock sophistication to generate high enough levels of grip to need that sort of camber
Not saying you are wrong, just thinking out loud
Cheers
Ric
try lowering your spring rates and backing off the damper settings for the back and the car might grip some more :happy:
^^^So, would changing the damper settings for the back, would give me more grip at the front? :stupid:
i assume your drifting the car, since your a mate of salad's, then lowering the rear damper will give you more rear grip, and more corner speed. stiffening everything up to make it break traction at the drop of the hat is not a good way to set up a car
^^^we'll try that for sure. The thing is that I dont have much power in my car so I I set it up that way to help out to loose traction easier at the rear.
However, with the new mods the car is putting out a bit more power now and I could tell today that the rear was just way too loose, but before I could so anything, I snapped a drive shaft and that was the end of it, tow truck home. :action-smiley-069:
Cheers
Ric
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
