Has any one fitted white faced gauges to there car before? I have a R33 series 2 and on ebay you can pick up white faced gauges for $75 plus shipping. But the thing is how hard are they to fit? Is it something i can do myself? and has anyone done it before? also are the legal to have? (cos everything these days is illegal!)
Thanks
https://www.sau.com.au/forums/topic/146327-white-faced-gauges/
Thanks
Adz,
I personally have white faced guages installed in my Series Two. To install:
1. Remove dash surround and remove dash cluster.
2. Unclip the front clear panel and expose the black bezel.
3. Remove bezel to expose guages.
4. The guage faces will have an enlarged center hole to slide over the needles... and sit over existing faces. For boost, you have to remove the tacho by unscrewing it from the back and pulling out from the front. The whole assembly should come out. (NOTE: DO NOT REMOVE NEEDLES)
5. Depending whether your faces are EL, remove all lighting bulbs except for warning lights and the one down the bottom right.
6. Again if EL, feed wires through where the bulbs used to do and hook up to 12 volt source (headlights)
7. Re-assemble and put back in.
8. You now have a sexy new dash.
Any more questions, give me a yell.
Cheers,
-Bman
i am after a set of these for my car but they only make them for GTS-T's =[
i COULD put the GTS-T ones in my car, but that is major wank factor concidering it will have the turbo gauge there... and no needle...
if anyone comes accross any for a GTS please pm me.
kthx
josh
ive got the white face for the dash cluster. but with mine its just all white and glows blue or green. it was a pain to put in because i had to take the needles off and it is a bitch to get them back on, spot on the right spot (adv to have a digital speedo and tacho).
but the rest was easy. just a mater of taking it apart, sticking them on, hooking up the wires, placing the dimer and back together again.
what will they fit in??
And also, these NISMO white faced gauges are 320kph and 11 grand tacho, as opposed to the stock 180kph and 9 grand tacho. Do you have to change cogs/gears at the back or somethin??
Sorry if this has been covered before, just wondering
Bman how much were your ones, and where did you get them ?
Alex_r33: They were about $90.00 + Postage
Josh: Im sure they do make them for the GTS's aswell, I got mine off ebay, have a look on there and try searching for EL GUAGES or similar and you should have some luck.
xtra.5: I didn't see the nismo guages until after I purchased these.... Should have waited a little while longer. :miner:
Cheers
  • 3 weeks later...
What if u just bought the whole instrument cluster? Would that re-calibrate it......i was thinking this, before when tossing up between the 320 vs 180 white faced dials. got the 180 cause seriously how often do u go above that. and on the drag strip u get told how fast u were going anyway! Plus personally i think they look better with just the middle lighting up and being able to jump between blue and green just by pressing a button.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
