acidkid Posted December 8, 2006 Share Posted December 8, 2006 Hi there just got a question for u all. My car's being playing up lately its stalling every now and again and sometimes i can barely get it started. I've done some reading on the forum and also mech's consult reading said there was a fault with the afm. Just wondering is the factory afm the only one that with work with a NA or will a turbo afm work as well? Also if anyone else has experienced this stalling problem pls guide me as i want to get my car going again. Thanks in advanced -Li Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/ Share on other sites More sharing options...
NA_R33 Posted December 8, 2006 Share Posted December 8, 2006 Havent experienced the problems mates but yes the turbo items are interchangable. Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2737283 Share on other sites More sharing options...
TurboX Posted December 8, 2006 Share Posted December 8, 2006 You can also clean the sensor with carby cleaner as on here if you SEARCH, but I have always used metho and a gas lighter to burn it clean and it always worked ok afterwards, Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2737339 Share on other sites More sharing options...
2rismo Posted December 8, 2006 Share Posted December 8, 2006 My ECR33 RB25 AFM is in perfect working order and for sale if you get stuck. Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2737351 Share on other sites More sharing options...
acidkid Posted December 9, 2006 Author Share Posted December 9, 2006 My ECR33 RB25 AFM is in perfect working order and for sale if you get stuck. how much u want for it? Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2737682 Share on other sites More sharing options...
2rismo Posted December 9, 2006 Share Posted December 9, 2006 $170 as is or $200 with a K&N pod filter. Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2737704 Share on other sites More sharing options...
acidkid Posted December 9, 2006 Author Share Posted December 9, 2006 $170 as is or $200 with a K&N pod filter. would it work fine for a r32 gts? Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2737787 Share on other sites More sharing options...
2rismo Posted December 9, 2006 Share Posted December 9, 2006 RB25 AFM Series 1 Wire A - Not Connected Wire B - Signal Wire C - 12v Ground Wire D - Signal Ground Wire E - 12v Power =============== RB20 AFM Wire A - Not Connected Wire B - Signal Wire C - 12v Ground Wire D - Signal Ground Wire E - 12v Power Same size and calabration as Rb25 AFM =============== Information taken from http://paulr33.skylinesaustralia.com Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2737910 Share on other sites More sharing options...
acidkid Posted December 9, 2006 Author Share Posted December 9, 2006 umm just had a quick check of my afm its in green colour as well but it has a code of 1909C dunno if it will still work and btw i have a RB25DE Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2738037 Share on other sites More sharing options...
2rismo Posted December 9, 2006 Share Posted December 9, 2006 Green sticker - I believe the atmo and turbo afm's are interchangeable. Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2738049 Share on other sites More sharing options...
acidkid Posted December 9, 2006 Author Share Posted December 9, 2006 kool any chance lowering the price and where abouts u located i want to get it asap so i can hopfully fix my car and drive it Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2738052 Share on other sites More sharing options...
2rismo Posted December 9, 2006 Share Posted December 9, 2006 No. Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2738558 Share on other sites More sharing options...
mickr33 Posted December 9, 2006 Share Posted December 9, 2006 Li you have PM...... Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2738621 Share on other sites More sharing options...
acidkid Posted December 9, 2006 Author Share Posted December 9, 2006 Li you have PM...... pm replied Link to comment https://www.sau.com.au/forums/topic/146536-afm-question/#findComment-2738622 Share on other sites More sharing options...
