Hey mass ur black 34 GTR is so hot :D ....Yeah this thread is for ur own 34 lol
hey man thanks...
Its actually a midnight purple not black :)
a little hard to capture the real colour... looks so diff in real..
Thanks... i gave up taking photo's of it.. its really hard to capture its true color... rather annoying.
Im going to get some pro shots taken when i get a chance.. but for now meh ill just stick to looking at it in person :P
let me take some pics masssss
Yeh for sure... u can have a go at it...
we will need to try and get the lighting right, otherwise it will either show up as green or black, too much light the car will look purple lol.. i want to try and get a nice pic of it with all the colors so it looks like the real thing.
Guys guys guys... read the first post.
There's threads for 32s and 33s, but what about 34s?
Post up your pics of 34s (not ones you've found on the net)
[/b]
there's another thread for general 34 pics from the web.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
