that ezyr34 is an r33! thats whats missing :D
Nothing gives that away :ermm:
Lol. I don't think thats whats missing.
ps. i can't put it in the R33 section, they'd kick me out :D
Edited by Owgasm
Haha, yeah, been looking for the front diffuser for months/years honestly!
The rear diffuser is a maybe if i can get one cheap.
I'm sure the problem is with most R34's that aren't V-Specs or missing the front diffuser is what makes it not look right.
One other way to tell its a R34 shell is its roof shape. I perfer it more than the R34 roof shape, its much more sleek and lower.
Hey all..some nice cars u all have!
Heres my old R34, sold her 6 months ago
Yeah, i remember this, seeing it at the Melb Autosalon earlier this year.
Saw it on the Dyno and must have been you with it.
my kit is bomex or bermex? i just picked it up 2weeks ago...
wtf r33 into a r34
is mine a fake r34? 1999 manaul r34 25gt non turbo >.<
how much is a turbo setup and is it easy to be done?
Edited by DeViLStaR
Yeah, thats what i ment about the roof shape ;)
Windows. geez, same thing lol.
Not as much as you'd think, but much cheaper than a R34.
Yeah, was based ona R33 GT-R V-Spec.
Also, the crease on the door, like basti said. For some reason you can see the crease clearly on it but when i see other R33's i can't see it :S
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
