Here's my precious baby that i been looking after for 4-5 months since i got it. Hope you guyz like it :P
Fully Dump
19 inch
Top Secret Front Bar
Custom 20 inch
20 inch
Full Ztuned Kit + 20 inch
Few bit and pieces of carbonfibre
Stef you are a hoe :) hahah
Lol...not as hoe as you yet :P. As for the wheels im using the 20 inch at the moment, the time attack and ztuned wheels is on the way but thinking going to sale them. So see how it goes.
Hey R-Spec
Front bar is a nismo one, i cut out all the brackets and crap that hold the number plate and opened up the mouth, i plastic welded pieces of plastic around the mouth to make it look genuine, with lots of plastic filling and sanding, once painted, bar looks genuine with a differnence
not a fan of them z-tune guards but thats just sex on pornographic rims! :down:
any more/bigger pics? what front bar is that?
CNBLOW nice car wingless ftw needs more dumpage!
I'm pretty sure that's the do-luck front bar on the white 34 with the black cf bonnet.
Hey R-Spec
OMG... please sell me your bumper! :down:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
