Bonnet is on the best that it can be... the RB30 conversion has set the overall height of the engine higher by 40mm and the front of it is fouling on the bonnet support (even with heat shielding off). Without lowering the subframe, cutting the supports, the only way we could achieve a closed bonnet was to space it up.
It's a bit unsightly... but then again the car was never built to be 'pretty'. Does a good job at venting away hot air though as there is now a clear route that heat can escape from under there.
Maybe later I'll get some custom guard moulds made up to blend up to the top of the bonnet (removing the gap). Will just make the front look mega-beefy.
Haha, you told me to show it off, Alex.
Getting it tuned on Friday. Considering how hard it already goes, it should be quite fun!
I want the LMGT4s, but obviously everything is so expensive at the moment. I may have to fork out for a set.
Thanks, fellas.
So, where to get the LMGT4s? I looked on Nengun, for 19x10.5, +15, it equates to roughly $4500. I'd be happy to pay that, though my last dealing with them wasn't the best. Anyone care to point me the right direction?
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
