Howie, mesh it i reckon.... if you dont mind hiding it then saves it from larges stones and debris as well as stealthy.
Here a couple of mine with the mesh...
RSPEC I've got a Trust Spec R-HG it uses the same piping as standard smic, yours looks to be a tad bigger maybe it is the Spec V i think? How much did it cost cause thats a easy way unless you got photos of it before going on.
Wanted something small and efficient for response.. the hybrid has a nice fin design which directs air in the front then comes out a regular core on the back. Apexi stopped production of these items so it's been pretty hard sourcing one for me. Anyhow so long as it works well to reduce heat soak i'm happy.
Howie,
How much has it set you back (I'm shopping for turn-flow FMIC now) if you don't mind sharing, PM if you prefer.
And what power level is it good for?
Very lovely 34 you got there (been pondering getting a 34 lately).
Cheers
Grant
totally getya. looks well made and seems to fit well. performance wise, its a good choice for response. i was just giving my opinon on the cosmetic aspect is all
Howie - paint the core! The end tanks make it look out of place; R34s deserve a big IC :) I hear your logic; but to be honest - even with my JJ FMIC under the 2.5L, response was pretty much the same as with the SMIC.
Might consider painting it down the track, but not really inclined to remove all that paint from the apexi core If I don't like it lol.
Oh btw, no cutting of the reo either :) So i've got a little room up top for my trans cooler.
bbtw, did you end up getting the rear diff for your car?
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
