just wondering if everyone if its ok with me makin a lil video of some of the R34's here on the site, just gathered up some pics and will show usernames etc on the photo. I started the video and i thinks its cool, its a lot easier than searchin through 90 odd pages.. helps get a good idea of which member has what car (34's only). goin through ever single page last night there are some sic 34's out there. Owgasm, ur a posting god, i think 20% of posts are from you. :)
let me kno what u guys and cara think lol think that was the only girl in the 34's thread.
All good here.
Haha, i like 34s... and i enjoy commenting others :rofl:
im gettin plates soon for mine, you guys think black plates/white text will look good on a white GTT? or should i stick with white plates/black text?
keep in mind i plan on getting black rims in future...
couldnt find any pics of a white 34 with black plates
just wondering if everyone if its ok with me makin a lil video of some of the R34's here on the site, just gathered up some pics and will show usernames etc on the photo. I started the video and i thinks its cool, its a lot easier than searchin through 90 odd pages.. helps get a good idea of which member has what car (34's only). goin through ever single page last night there are some sic 34's out there. Owgasm, ur a posting god, i think 20% of posts are from you. :banana:
Sounds good! Im up for that. Let us know how it goes. :thumbsup:
<----- Ohh i missed this comment. . . My R34 is white with black plates and white text. . Best way to go!
hey Ken video is done, nothing crazy just somethin i did quick so people can enjoy 34's from our own site not everyone elses u see on the net. Sorry i didnt put the hot pic of the 34 in ur display cos i thought it was ur mates.? just tryin to put some of the members ones up.
Any ideas where to post it? i have a couple versions one is 10mb crap quality other is around 40mb with bit better quality. both versions go for 7mins.
The R33 in the back is my mates haha. Hmmm Maybe start a new thread? Or maybe ask the admin where would be the best place to post the vid?
just wondering if everyone if its ok with me makin a lil video of some of the R34's here on the site, just gathered up some pics and will show usernames etc on the photo. I started the video and i thinks its cool, its a lot easier than searchin through 90 odd pages.. helps get a good idea of which member has what car (34's only). goin through ever single page last night there are some sic 34's out there. Owgasm, ur a posting god, i think 20% of posts are from you. :wacko:
the linky is no worky :blush:
