Its been ages since I posted in the picture threads so here are a couple of my recent purchase: 34 Vspec
Just fitted 19 inch GTCs and yes it needs lowering!
Love GTCs mate, and the colour combo looks great on your car. Just wondering though, what size tyres are on the 19"s? They look a bit thin in the aspect ratio (overall circumference of the wheel looks a bit low) - does the speedo read high?
@KSR
You put my white 34 gtr to shame mate!
Love the use of the black or is it carbon in the bonnet and spoiler feet and mirrors to create a nice two tone effect without painting half the car lol
Is that a custom or top secret rear diffuser? Massive by the looks of it.
If you don't mind saying even in pm could you tell me where you got the bit that sits above exhaust all along the rear bar and other cosmetic bits?
That rear bar carbon cover can be found on ebay. Have been eyeing in for a few days now actually.
Probably not the same, but if you can source it elsewhere, here's an option:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=320679163825&ssPageName=STRK:MEWAX:IT#ht_1482wt_1141
@KSR
thanks mate,
bonnet is full carbon, sprayed white leaving the vents.
front and rear diffuser are top secret.
btw whole car was done at bodyform.
