Too far away?
Well perhaps, with God_speed's absolutely stunning Black VS2 Nur, Matthew VonMatBoy can do something with these? ^^^
Those comments a couple of pages ago are much appreciated guys...
Terry, we'd love to have you join the party!! Google says it's 3,938km's from Sydney to Perth, so as long as you don't mind a few kays on your car come on over! :D
But seriously, it looks mint. Would look good next to Dave's N1 here, that's pretty mint as well - 12,000km's on it! :thumbsup:
Love the photos Matt and Clarence - keep 'em coming!
Kinda left Huy's black Nur out of this shot by accident... but it was there! Sorry Huy.
Would've been better minus the lurkers and random cars in the background!
Edited by 32godzilla
Marko, I'm located around Sydney and I'd be happy to shoot your ride. I'll PM you :)
Tangcla, love your work man! Pics 2 and 4 are rad. The red came up a treat!
One more of the same 34 for you all...
Thanks Mat!
This rolling shot, did you use a rig or second vehicle? I'm very hesitant to use a rig, all my rolling shots are done with me from a second vehicle.
I see the other R34s are all having rear tail light syndrome.
Some cars light up a whole lot better than others.
Mine fail, people think they're out/not working during the day.
I feel slightly ashamed putting my car here, it doesn't have a home.
But closest to the R34s.
Just a sneak peak from a shoot. Let him play with my car.
Photographer is a kid in high school that I went to school with, still learning, but better than anything I can do for now.
Thanks so much for the extra photos. Please post more if you have them.
That black one with the TE37's looks fantastic. Love it.
Edited by iwanta34gtr
Nice car mate.
Domo kicks ass. Nomnomnomnmonomnomonomnom
^^^ Yeah very nice, sits really well. Okay one more - it's on the dark side but I think Marcus' car (M-Spec Nur on left) looks really nice, as does Huy's of course! Genuine Nismo (R-Tune?) CF bonnet is drool worthy too!
OHHHHHHHH
i would be keen but i'm flying to europe on good friday
faaaarkkkk. my car hasn't left the garage since july either
Well, I could come get your car from the airpor (I land on Thursday) and use your car for the weekend... I'll drop it off on the way to the airport ;)
Complimentary vehicle pick-up and drop-off service, normally valued at (insert dollar value here)
im keen to hear more bout this shoot as i live in wollongong n wouldnt mind some more pro pictures of my car
Just awesome. But how dare you leave the black Nur out!! Haha :P
Couple of my car, sorry can't rotate first photo, second, these two are related, believe it or not
The Targa twins!? Love it.
Thanks
I'm not sure honestly, i'm just looking after the car :P but I don't have a V-spec one to replace it with haha.
Haha!
http://justjap.com/s...&cat=335&page=1
^^ Come on! Get it together.
Just joking ya :laugh:
You still running with the TE37's or the Enkei's?
Any further from Brisbane?
I may have to trailer it though...
6000kms and not counting... much.
So much dust.
Xenons are in the cupboard :)
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
