^^ TE37 SL 19 x 10.5 +12, but from memory the previous owner of that car ran a spacer at the rears for a bit of poke.
noriyaro_rgf_r34_gt-r_nur_002.jpg?w=700
If you went the TE37 SL or a Black set of Nismo LMGT4's, it'd give you the tough look.
Agree on the black (GT500 centrelock-look) LMGT4 suggestion above!!
Tada! Dodgy photoshop with RE30 clubsports:
Edit: Actually, unfortunately AFAIK the clubsports are only available in a maximum of 18". But you can still get some 19" RE30s, fomula silver is the best colour IMO (similar to the clubsports) as opposed to the chrome silver, white or bronze for RE30s
Edited by God_speed
Jade on Bronze isn't the best combination in my opinion.
Black/White/Bayside Blue on Bronze is best.
People tell you to be different but.. its hard to be different when the common way is the common way because it looks better.
I have gt500s hehe :yucky: and a few other thousand wheels too :( its bad.
Welldone on the purchase!
Just to clarify, is the RB26 stroked to a 2.8lt along with aftermarket turbos?
I'd stick to the Nismo LMGT4 wheels you have and in that Bronze colour too! But just go wider and more aggressive offset.
Millennium Jade and Bronze give you the clean look.
And it being a Nur (bit more of a collectors item) I'd keep the Nissan / Nismo theme going through it.
If it was me, I'd get the same wheels / colour but go for a 18 x 10.5 +15 or +12 and test fit that.
Yep its stroked to a 2.8 but still has n1 turbos. Super responsive!
Yeah 10.5 is the go! Black LMGT4's are unreal! Thanks for the pic that looks amazing!
WOW Matt that looks freaken unreal!!! Awesome photo shop skills man! Thanks for that! I don't know what looks better lol LM's or RE30? Love the colour though. I would prefer 18" for track, mix it up with the other set for street as well. It would be like deciding on what shoes to wear when you go out haha I think im leaning more towards the RE30's there is just something different about it
Thanks Marko
and no worries I enjoy doing that sort of stuff. :)
The RE's are very light weight as well. When I weighed my 18x9.5 +15 ones they were about 8kg each.
Simon (N11smo) is selling the set that he bought off me; but sounds like you'd want something slightly wider.
Ah I see.
Yeah for sure, always love a super responsive GTR :thumbsup:
All good, post pic of new wheels when you get them :D
My one has got the Te37SL's 19x10.5+22. Will post an updated pic when I got a chance.
I am sure I have a pic of your car but I will leave it to you to post :P
upload to photobucket/flickr or something, then when you go to post, at the top where "bold" and "italics" are, to the right you'll see an "image" button. paste your photos URL there and done.
i was stuck to hope this helps
http://www.skylinesaustralia.com/forums/index.php?app=members&module=messaging&section=view&do=showConversation&topicID=1104526&msgID=__firstUnread__
Finally uploaded a couple. Not the best quality but oh well. When I got my car lowered, I had to get modified rear camber bushes and run as much positive camber due to the coilovers external oil canisters hitting the inner rim due to the width and offset of the rim. The guys at centreline suspension did a great job with fine tuning the coilovers and adjusting my cusco negative upper arms.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
