^^ TE37 SL 19 x 10.5 +12, but from memory the previous owner of that car ran a spacer at the rears for a bit of poke.
noriyaro_rgf_r34_gt-r_nur_002.jpg?w=700
If you went the TE37 SL or a Black set of Nismo LMGT4's, it'd give you the tough look.
Agree on the black (GT500 centrelock-look) LMGT4 suggestion above!!
Tada! Dodgy photoshop with RE30 clubsports:
Edit: Actually, unfortunately AFAIK the clubsports are only available in a maximum of 18". But you can still get some 19" RE30s, fomula silver is the best colour IMO (similar to the clubsports) as opposed to the chrome silver, white or bronze for RE30s
Edited by God_speed
Jade on Bronze isn't the best combination in my opinion.
Black/White/Bayside Blue on Bronze is best.
People tell you to be different but.. its hard to be different when the common way is the common way because it looks better.
I have gt500s hehe :yucky: and a few other thousand wheels too :( its bad.
Welldone on the purchase!
Just to clarify, is the RB26 stroked to a 2.8lt along with aftermarket turbos?
I'd stick to the Nismo LMGT4 wheels you have and in that Bronze colour too! But just go wider and more aggressive offset.
Millennium Jade and Bronze give you the clean look.
And it being a Nur (bit more of a collectors item) I'd keep the Nissan / Nismo theme going through it.
If it was me, I'd get the same wheels / colour but go for a 18 x 10.5 +15 or +12 and test fit that.
Yep its stroked to a 2.8 but still has n1 turbos. Super responsive!
Yeah 10.5 is the go! Black LMGT4's are unreal! Thanks for the pic that looks amazing!
WOW Matt that looks freaken unreal!!! Awesome photo shop skills man! Thanks for that! I don't know what looks better lol LM's or RE30? Love the colour though. I would prefer 18" for track, mix it up with the other set for street as well. It would be like deciding on what shoes to wear when you go out haha I think im leaning more towards the RE30's there is just something different about it
Thanks Marko
and no worries I enjoy doing that sort of stuff. :)
The RE's are very light weight as well. When I weighed my 18x9.5 +15 ones they were about 8kg each.
Simon (N11smo) is selling the set that he bought off me; but sounds like you'd want something slightly wider.
Ah I see.
Yeah for sure, always love a super responsive GTR :thumbsup:
All good, post pic of new wheels when you get them :D
My one has got the Te37SL's 19x10.5+22. Will post an updated pic when I got a chance.
I am sure I have a pic of your car but I will leave it to you to post :P
upload to photobucket/flickr or something, then when you go to post, at the top where "bold" and "italics" are, to the right you'll see an "image" button. paste your photos URL there and done.
i was stuck to hope this helps
http://www.skylinesaustralia.com/forums/index.php?app=members&module=messaging&section=view&do=showConversation&topicID=1104526&msgID=__firstUnread__
Finally uploaded a couple. Not the best quality but oh well. When I got my car lowered, I had to get modified rear camber bushes and run as much positive camber due to the coilovers external oil canisters hitting the inner rim due to the width and offset of the rim. The guys at centreline suspension did a great job with fine tuning the coilovers and adjusting my cusco negative upper arms.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
