Nice colour.
More pics please :)
thanks mate, yes this is GTT, but with full GTR bodykit (rear and front fenders, bumpers and sideskirts). the paint is House of Kolor candy Cobalt Blue over silver.
now the car is too high, waiting for cusco coilovers. already installed bride stradia seats. soon will post more pics :)
Nice collection. The last shot could've been taken from a tracking car without a rig, as the car (the subject) is driving straight anyway (not turning).
But Matt Everingham's taken some great rig / boom shots in the past, e.g.
Call me ignorant but I have never heard or seen a gt500. What is the highest spec r34 (z tune?) And how does the gt500 compare to this?
How many were made in production?
they're talking about the lmgt4's which are the limited 'gt500' edition in grey with special centre caps
Yep, I have seen his flickr album and they are absolutely amazing.
i'll be honest. i did think of this for a second.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
