A few quick snaps of my 34 when I got her back in April, also a couple of pics from a Bells Line run and run to Nepean River
http://imgur.com/a/oTz6K#0
Trying to find someone I know with a decent camera to get some better photos
Adam, ^^^ I'd contact MaTBoY here on SAU or through his site www.autocult.net
...and ask him when his next photoshoot is on?
He's doing a photoshoot for the OzFoz car club this Sun > rolling shots
Thanks Terry, I've seen Matt's work and it's excellent (currently have2 of his pics as my wallpaper for work)
I'm working this sunday but i'll drop him a line. Cheers
If your car had a Top Secret front lip, it would be complete.
Don't do it! Top secret diffuser looks gay on standard r34 front bar. Needs Z-tune or Top Secret bar to make it flow. I considered, but I thought it doesn't look that good imo.
Here's a pic before I sold mine :)
It will have Front and Rear Diffusers fitted over the christmas period... Should have the Nismo Vents fitted too, just gotta get them clear coated first :yes:
No fancy pics from me this time, but had to join in on the bayside blue goodness.
Just got her back from getting her bonnet, bumper and lip repainted to remove all stone chips - etc and took a few happy snaps.
Fitted replacement headlights today as well.]
One of my favorite GTR on this forum!!!
Where did you get the carbon oil cooler ducts from?
Is the fit OK, as it looks like a few gaps, but might be just the photo?
Looks great, well done.
The SP1 are such a good looking wheel.
Where did you get the replacement headlights and how much?
Mine are looking quiet old and foggy and I would love to update like you have done.
I used this guy to fix one of mine when a panel beater had drilled through the back of it slightly enough to let water in... refurb to brand new can't tell the difference between original and refurb one:
http://www.drgtr.com.au/index.php?option=com_content&view=article&id=86&Itemid=78
I get bored in my spare time so just go off on tangents and make random crap for my car.
Fitment is not perfect, because they weren't moulded from genuine plastic parts. I expected this.
With some slight mods they should almost line up across the face of the bar, only the side one might need a bit more work.
They look off because I have a plastic bar bent over the wheelie bin.
Will post up some close ups once I've fitted them to my car, the blue GTR front bar was to hack up and practice, lets hope practice makes perfect.
I don't like to idea of cutting holes in my MPIII front bar but all for a good cause. Once there fitted I'll get an oil cooler kit fitted there.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
