A few quick snaps of my 34 when I got her back in April, also a couple of pics from a Bells Line run and run to Nepean River
http://imgur.com/a/oTz6K#0
Trying to find someone I know with a decent camera to get some better photos
Adam, ^^^ I'd contact MaTBoY here on SAU or through his site www.autocult.net
...and ask him when his next photoshoot is on?
He's doing a photoshoot for the OzFoz car club this Sun > rolling shots
Thanks Terry, I've seen Matt's work and it's excellent (currently have2 of his pics as my wallpaper for work)
I'm working this sunday but i'll drop him a line. Cheers
If your car had a Top Secret front lip, it would be complete.
Don't do it! Top secret diffuser looks gay on standard r34 front bar. Needs Z-tune or Top Secret bar to make it flow. I considered, but I thought it doesn't look that good imo.
Here's a pic before I sold mine :)
It will have Front and Rear Diffusers fitted over the christmas period... Should have the Nismo Vents fitted too, just gotta get them clear coated first :yes:
No fancy pics from me this time, but had to join in on the bayside blue goodness.
Just got her back from getting her bonnet, bumper and lip repainted to remove all stone chips - etc and took a few happy snaps.
Fitted replacement headlights today as well.]
One of my favorite GTR on this forum!!!
Where did you get the carbon oil cooler ducts from?
Is the fit OK, as it looks like a few gaps, but might be just the photo?
Looks great, well done.
The SP1 are such a good looking wheel.
Where did you get the replacement headlights and how much?
Mine are looking quiet old and foggy and I would love to update like you have done.
I used this guy to fix one of mine when a panel beater had drilled through the back of it slightly enough to let water in... refurb to brand new can't tell the difference between original and refurb one:
http://www.drgtr.com.au/index.php?option=com_content&view=article&id=86&Itemid=78
I get bored in my spare time so just go off on tangents and make random crap for my car.
Fitment is not perfect, because they weren't moulded from genuine plastic parts. I expected this.
With some slight mods they should almost line up across the face of the bar, only the side one might need a bit more work.
They look off because I have a plastic bar bent over the wheelie bin.
Will post up some close ups once I've fitted them to my car, the blue GTR front bar was to hack up and practice, lets hope practice makes perfect.
I don't like to idea of cutting holes in my MPIII front bar but all for a good cause. Once there fitted I'll get an oil cooler kit fitted there.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
