Sorry its not the best, taken from ipad lol.
Well, well, well !!!
There she is!!!
The Winner of Best Concours at the R34 GTR 10th Anniversary!!!
Prepped by Eugene Chan. Btw did you receive a copy of the Certificate signed by Mark Skaife?
There she is!!!
Hey Terry, i have the award but there's no writing on it at all. I did recieve the calender though...
Damn Reece it is good to see this again
Hope she is running well
Hey Matt, She sure is! Cant thank you enough for handing her over :yes: Still yet to see a cleaner example of her :wub: lol. The ipad camera doesnt do it justice.
Good to hear. where is the build thread mate? :P
Need to see more pics...
Modified 34R skirts to fit gtt rear fenders ^
That looks tough! So many cars with the front end only and they really do look dissapointing or unfinished, you sir have nailed it :D
Haha whoops, I really should have stated that it isn't my car guys!
It's a car located in Japan that I'm using as the inspiration for my build (my car goes into the body shop very soon to get work done).
Nismo front with custom lip, flared rear fenders, MNPI respray, among other things.
I won't go into any more detail :no:
Ohhhhhhh :P
Well i look forward too seeing the result!
What rims will you be running with it etc?
The result should look like the above pic :)
CST Hyper Zero in 18x9.5 +15, which should be here hopefully by friday. Will post test fitment pic on standard guards.
May have to run spacers when i go wider until I buy some 18x10.5+15's
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
