R34s...please!
NS2500
Thanks Terry,It certainly does.1st anniversary today ,Good Friday,it's been twelve months since Alicia at iron chef rang me to say it was mine.When i picked it up from japlink it just blew me away.The auction photo's just didn't do it justice.P1010175_zps9c355873.jpg
Beautiful car you have there. Can't wait till my Black Vspec arrives in Aus. Thanks Iron Chef/Troy and Alicia!!! counting down the weeks!!!
Whats done to it... very nice 34...
I can only compare it as being a passenger, but to me the porsche's handling felt so crisp and responsive. Compared to the gtr its hard to say as I didnt drive the thing but unmodified in any way the porsche just changed directions with ease with no body roll whatsoever. Compared to the gtr if it were stock you have to upgrade the suspension to make it feel like that. The brakes on the thing were awesome. I think there the same size as the gtr but the porsche weighing around 250-300kg less makes u huge difference in stoping power. Power delivery is on a different level being a 3.6 litre. There is so much grunt down low that it just pulls you hard than at around 3k revs its even harder. There is hardly any transition onto boost, just a feeling that you know it is on by how much harder its just pushed you into your seat. Owner said he ran a 12.4 stock. The only thing I didn't like about the porsche is that its so quite but thats an easy fix with a exhaust and some induction mods. Apart from that in my opinion you don't need to touch it whereas the gtr you have to spend a bit of money to get it to that level. 300kw in the gtr, a good set of coilovers, sway bars and brakes and you will out do the porsche. Pretty much were im at now with the brakes on there way:) at this level there really isn't much the gtr cant play with
ive always had a soft spot for Porsches & if I bought a car of this calibre - I'd choose Porsche over its rivals.
Apparently a real drivers car, simple but built to be fast.
Sorry guys a bit off topic :)
Drive a 993 turbo they were the best of the lot, we modified one and got 320kw at all 4 (didnt want the lag being a circuit car) and it was just insane.
If one came up at the right price I'd sell both my cars to own it
yep marko summed it up perfectly 'built to be fast'. The gtr can do what the porsche can and may even do it better but you need to spend big bucks on the gtr to be able to do it reliably.
Brett you probably wouldnt lose buying a 993. They been floating around the same price for years and will probably go up in value in years to come.
Did it take much to get 320kw out of it?
    • Awesome to know. I have a Series 1, and When pulling my front bumper off for the first time i realised my reo/crash bar was a bit worse for wear, and was going to try pick up a better one soon just so i can replace it. Someone is selling a full series 2 front bar and brackets for a decent price, so was going to probably reuse my brackets and install the new second hand reo/crash bar. I also have a genuine Altia body kit to do up, spray and put on, and not sure if that will use the series 1 or series 2 brackets for the front bumper, so having both will be handy, and knowing i can drill holes out to make stuff fit between series is also handy to know!
    • I should also say that the while they are different the only parts that matter are the center headlight supports and center bar from S1 to S2. The center bar will work, but the S1 has holes that clips go through into the S1 bumper. So if you were super cheap you could simply drill the S2 bar. Same thing with the side/wings. They have slightly different 'clips' but can be made to work. The center headlight brackets however, cannot. This is also where the GTR differs, which has a different center bar, and different headlight supports (to either GTT system), it also has different 'wing' headlight supports which is what I am calling under the headlight. However those CAN be made to work with the GTT Reo for a GTR front bar by a small spacer and a drill/tapping a thread into the reo because the bolt positions are slightly different. So people only really need the center brackets to go between GTT S1, GTT S2, and GTR if you are happy to do some tinkering.
    • Indeed  😃  Appears the site is back up now (migrated not updated) - kudos @funkymonkey & @PranK
    • If this, then this You can't really get away without it. There are hacks that you can do in Nistune, but things are much easier with the sensor than without it. If you're not planning to Nistune the ECU, then stop right now and add it to your plan anyway, because the ECU is going to shit the bed over the missing ABS and TC computers that it expects to see, and you need Nistune to stop it chucking all its toys over the side of the crib.
    • hey guys, so ive done a complete +t conversion using mostly stock parts on my rb20de neo r34.  Im wanting to know if a boost pressure sensor is needed? Seems like the engine cuts out when i try to do a pull and I have a feeling its because a boost pressure sensor is missing. I'm using a stock r34 rb25det neo ecu.
