I took Maria to a movie the other day > get her out of the 4 walls.
At the cinema, I parked slightly to the left.
She got out of the car and looked at my car's alignment.
I knew what she was going to say, so I yelled, "Have you ever seen a penis that hangs straight!"
She laughed and then enjoyed herself :)
Haha well said Terry.
hey adam, not sure if it's just the angle of this pic but does your cannon hang to the left? cos mine does, and noticing yours, it's kinda curious that both ours do.
Well, since psychologists (not including myself), say that our cars are extensions of our penises, I couldn't resist!
Rofl
Ummm...
Back to Pic or Penis!
Guys,
Matty Gava is selling a Z Tune style carbon bonnet at the moment, looks mint and is only $700
Its all over Facebook but i figured all you GTT lovers may want the first chance at it :)
I would grab it but i am trying to keep mine looking stock :ph34r:
Here is the FB pic -
