Some pics of the new carbon boot
I'm so torn right now as to what to do....
options are:
1. paint carbon boot white to match car and leave it
2. fill and paint original boot so there are no holes and sell on carbon boot
3. buy a carbon bonnet to match the boot
gutter rash on wheels to be fixed soon and the inserts will be painted black so i think the whole carbon boot/bonnet with black wheels would look swell.
But it kinda defeats the purpose of the car. want to keep it simple and clean looking and nice and legal.
so i think option number 2 is looking the best so far.
What do you guys think?
Steve, if you plan to keep the boot, get the bonnet to match. Otherwise leave it off I reckon and just fill and paint the original boot like you said.
Carbon boots are sort of love/hate type of thing, I reckon they only work well if you do the whole car panda-style... e.g carbon bonnet, painted roof, carbon boot.
Yeah i saw that white r34 that had the panda style happening (member from here, forget the name though)
Wasn't completly sold on it, i'd have to work into it i guess.
i'll probably change my mind 20 times before i decide on something. but i'll probably end up fixing the old boot. i just dont trust having carbon fibre everywhere because of police/insurance issues. i do like the look of it though
if your planning on making your car into a track car, keep the carbon boot (weight reduction) but if not, just fill up the stock one and paint it.
I dont really see a point in carbon fibre boots unless your car is for track..
hoods is a different case because they got vents.
each to there own
yeah seems to be the way to go.
defs never going to be a track car. i think i'll stick with my initial plan of keeping it standard looking (aside from the pretty wheels) and aim to hit the 260ish rwkw mark
any idea how much those boots usually cost to get filled and painted?
Just got mine back yesterday. Got no money for VOLKS or RAYS so i did the cheapo option, a respray. Rims were sandblasted then covered with a special teflon paint (matt black) so its easy to clean. I reckon if you twist your head to the side and use your peripheral vision my car looks likes a Z TUNE GTR :D ..
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
