Hey Adam, do you ever have issues with rain with the z-tune bonnet?
nice ride indeed + for the Z-Tune Bonnet
Hey Doski
Well i wont drive it in the rain but if i do there is a screw up undercover to stop most of (Not All) getting in and it came with the bonnet. and i leave the cover on as i never know if i am going to get caught in the rain somewhere.
Adam
Hi guys, got my Tein Monoflex coilovers and Nismo skirt kit fitted a few days ago. Heres some pics I took today:
See if you can spot my SAU sticker :D
My Volk GTC wheels will hopefully arrive from Japan late next week. I have a feeling that the GTC's will look better than my stock wheels :bunny:
Will post up some more pics when wheels are fitted. Cheers
Yeah mate, lowered it some. Cut a fair bit of the gap out between arch and tyre, especially at the front.
When they first put them in it was slammed, had to raise them up some.
Dont think I will lower them anymore than they are now as it would just be ridiculous for driveways, etc. The rolling diameter in my 19s that Ill be getting will lower the car a couple of mm more as the tyres will be 30 profile.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
