Well what can i say. WOW. Fantastic everything. After being quoted a very reasonable price
i decided the give these guys a go. Dropped the car of in the morning and later on in the
afternoon received a call saying there were small problems, i was both disapointed and
thought WTF will this now cost me? Anyway Drew told me to come in and discuss it. It was
missing and not running right. Anyway after leaving the car with him he spent time trying to
rectify the problem, then finally fixing it. He installed all my goodies and dyno tuned it.
Ended up with a great result and he did not charge me one cent more than was quoted.
Even stood there when i picked up the car for about 45 mins answering all the questions i
had. A credit to Drew, Izzie and all the other guys down there. Will deffinately be back for
when i break something. :P
https://www.sau.com.au/forums/topic/146585-my-experience-at-selectmaz/
Nice one Mick. They are pretty damn good at the rotary stuff but that flows on to other cars as well. I'll be taking both the GTR when Aaron sends my huffers out and the track beast for tunes once work is done.
They love a chat as well which is great too.
So other than the Sliding turbo what else is on the car? That was good power from the hiflow (I read the other thread) so I could almost dump the idea of the TT's on the trackie. I'd only be making a bit more power.
G'day Geoff. The other mods on the car are a power fc, bosch 040, nismo fuel reg, Z32 AFM,
FMIC, full exhaust and a turbotech boost controller which works very well at high levels. I
didnt mention injectors because the standard ones were used. Only upped the pressure a
bit and all is fine on the hand controller. 90% duty is the max i've seen and the knock levels
are not exceding 20 at the moment. :P
SelectMaz were very good Customers of mine up in epping. The boys there absolutely loved to have a chat and the work they did was absolutely top notch!! They always beleived in using the best stuff and I think the work they produce reflects that!
In my opinion it is one of the best Performance shops in the North Eastern Suburbs! You get what you pay for.
Glen Ridge gets his S6 Rx7 setup and tuned (powerFC) there ive met him there once!
Hello Guys,
Well what can we say but Thanks, Drew has had a lot of years with Skylines and with Waynes tuning the combination works well. We hope more people will give us a break and realise that we do all performance cars not just the Mazda's.
Oh and Geoff make sure you pop in and say hello before xmas.
Bye
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
