ey guys,
did a compression test today, however, i disconnnected every hose when i removed the intake manifold and removed all the spark plugs, then i performed the compression test.
Cylinder:
1. 146 PSI
2. 145 PSI
3. 147 PSI
4. 145 PSI
5. 146 PSI
6. 145 PSI
i dunno wat the go is.. And is this the way u do a compression test or not? by removing all park plugs and then cranking it?
https://www.sau.com.au/forums/topic/146595-compression-test-for-rb20det/
ok....so keep all plugs in, take one out, test it, then put it back it, then take the next one out and test it yer? do i loost compression when all spark plugs r out? coz i just cranked it till it popped...
Depends on how your gauge reads dude. A lot of low qual gauges about that read way off.
Also rb20 donk is fairly low comp I'd expect 130 - 150.
You look more for variation. The readings on your engine are awesome !!
around 150psi is normal for the age the engine,manual specifies 170psi with the limit value (lowest) 128psi, the variance limit shouldnt be more than 14psi beween cylinders
u should have the engine close to operating temp at least, remove ALL plugs, attach gauge to cylinder (screw fitting is the better ones), depress pedal FULLY u must have WOT, crank till needle stops moving which should be about 7 engine revolutions, then record ur readings,
urs seem good not much variation which is good
im not sure if the readings will be lower or higher when stone cold as i have only done it when at operating temp.
maybe someone can verify that as my engine is not finished yet to be running
cheers,
brad
Edited by RB20/30Det_VL
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
