Hokay , many arguments over this but how can I positively identify the 480 or whatever cc side feed injectors . There must be a colour and part number on them so can anyone state 100% what it is . Everyone seems to agree that JDM manual S15 turbo's have them .
Cheers A .
Edited by discopotato03
https://www.sau.com.au/forums/topic/146846-s15-sr20det-injector-details-please/
  • Replies 71
I've just bought a set and they are no where near the red shown above.
More a shitty light brown
Is that the 'Teracotta' colour?
(definatley not the pruple ones, seen them before)
I assumed they would be red but now with the 'terracotta' talk, are we saying there are 2 different coloured injectors for the same type?
I'm hoping it's a yes as I'm a tad worried i wasted cash on these 4.
Also, i have a set of 4 brand new ones coming over from Japan. (with a GTR R33 pump...yippee!)
I'll flow test these brown ones and give my results
Also, I'll give a quick photo of both colours side by side.
Oh yeah, I'll also have 2 spare left over for anyone hunting down a set of 4 and need the extra 2 :)
Well, i got em today.
4 brand spankin' new s15 injectors with all rings included.
I also have 4 used as well.
I don't know why but every photo I've seen (including the ones I've taken) look redder than what they are. Go figure??
Here's a comparison of new to old, easy to tell which is which although the old look pretty good too.
..and some pics of the extra parts you need if buying new.
Edited by Birnie
If someone could elaborate on this it could be useful.
Don't know where it was sourced from but considering all the theories on what these flow, it may help.
Looks like standard fuel pressure is 450cc and up to 525cc's under the right pressure? (not sure if I'm reading it correctly)
http://www.williams.co.tt/s15/inj_side-en.htm
Ok I gived up searching . Are the seals used on RB25DET (R33) the same as SR20DE/T ?
I gather the O rings are upper and lower on the injectors themselves and the thicker square section seals fit on/in the manifold and the rail locates inside them . What about the other little gadgets - caps of some sort .
Would be good if Nissan (or someone) did a kit of seals to R/R RB25 injectors and if so part number .
I suppose Brighton Nissan spares would be the place to look in Southern Sydney .
Cheers A .
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
