Hi, I have a 1985 r30 hatch with power windows that has registration due on wednesday, and failed it's inspection today due to not having the controls for the rear power windows in the rear. I'm around the Sydney area and need to buy or (if someone is very kind) borrow the rear passenger and driver power window control switch things. The wiring is all there, just need to plug it in then take it back to get pinkslipped and registered.
Like I said, I'm in Sydney in West Ryde. If someone can help me out with some spares, shoot me an email at [email protected] or reply here.
Cheers.
Edited by HunterDevourer
Cheers.
your best bet is to just try a few wreckers
can you use some switches from another car (R31 Ti? Mazda 626...)and retro-fit them to suit?
if the look stock enough it might work, im sure they dont know exactly what r30 power widow switches look like
It must be different in NSW, but when I tried to get my R30 rego transferred here in Vic, the driver's window didn't work, and it's the only one that MUST work. So I simply swapped the motor from the rear RH door into the front RH door, and Robert became my uncle.
It passed a blueslip without them last year, but failed the pinkslip this time because of them. Different mechanics. I had no idea it was a fail item, and most people i've talked to don't think it should be. I've bought some bits from jaycar but couldn't get them working (2 switches with off position in middle, power on up and down).
I might be able to retro fit some switches from other cars like the r31 etc....but I now can't drive anywhere to get them.
I checked out drivers side power window door control as well, but it's no help as it has a different number of wires anyway.
  • 4 weeks later...
I had the same problem and ended up using a C31 Laurel rear switch for a while that worked fine, I'm guessing anything of that era would be more or less interchangeable. They're not the same cosmetic design, but the wiring is identical.
Those R30 rear switches are a downright pain, the internals always fall apart and then you're stuck with the whole assembly in several pieces. Must be something to do with the way they're vertically mounted on the doorcards, people push on them too hard and over the years they just get more and more worn out until they finally break. In fact I'd probably say that the C31 switches (which were designed for horizontal mounting) are far more robust than the R30 ones.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
    • Alrighty, I'll have to grab a couple pics and type out something soon in another post. I haven't driven a modern X no, this would be the first one really. Yeah the rental boxes are always cheap as chips right? So I'd doubt that anyone was handing out GTs to go and abuse. But I s'pose I could be wrong for sure. New cars these days though? Pretty unimpressed with what I see now; 20 years and all that, like you said. It just kind of worked out to have these two cars now. I'm pretty pleased with that, don't need much else. I'm sure you lads are right about the temps and for sure, you wouldn't have much time to drive 'em down there if you all were like me. I do hate sweating all over the seats though😆
