Pauly33GTS-t Posted December 11, 2006 Share Posted December 11, 2006 Alrite fellas I need some ideas, im gonna be paying for the car on wednesday it looks like it when the report from the RAA comes to me 2moro night. then ill have 3 or so grande left over to mod it a bit, its sitting at 153kw and it has aftermarket air filter and after market exhaust. has 2 BOV sitting in it too but 1 is disconnected. I am getting rid of the blitz BOV and the other one (i forget what it is cause i am skeptical) but I'm asking the people. what would you do to a stockie when u got 3 grande. and no i dont want after market rims n shit cause i get free rubber for the stock rim size from bridgestone. (family rates pretty much). im not big on show i mean ill lower it a bit but im more interested in power, and sleeper look. Also, to make this SA specific, who are the guys to see for their individual specialities on mods. would suspension/ FMIC and external waste gate be on the order top of the list? Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/ Share on other sites More sharing options...
Bl4cK32 Posted December 11, 2006 Share Posted December 11, 2006 external gate...no Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2742200 Share on other sites More sharing options...
mr_rbman Posted December 11, 2006 Share Posted December 11, 2006 why an external gate....................you do know what they are? You've basically answered your own questions. See sydneykid for the groupbuy on suspension and one of the sponsors will do you a good deal on an intercooler kit which should leave you some cash to get it installed if your not too mechanically minded and if you have enough free cash get a fuel pump. Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2742230 Share on other sites More sharing options...
4door_Sleeper Posted December 11, 2006 Share Posted December 11, 2006 Ok, here is the stock list you need to get the power you want Exhaust - (u have it already) but make sure you have a split dump pipe on it Cold air intake - You could add a pod in a box (ie Maxx's group buy) or just get a decent panel filter for the stock box (good for over 200rwkw and the cheapest option) Intercooler - Dont need anything too special, just a reasonable front mout will do the job. Boost controller - a simple bleed valve if the budget is tight, but some of the electronic ones are available at great prices (especially second hand) and are well worth the cost as they offer much etter control and protect against oost spikes and drop off. Fuel pump - if yours is stock and the car has over 80,000km its probably going to struggle with the bigger horsepower, so check it out and replace if necessary Electronic fuel and ignition management - I prefer the PFC, but their are other options (again second hand is fine) Dyno the whole lot once all of this has been installed. As mentioned SydneyKid has a great group buy on suspension, but if cash is running out at least invest in a set of pinapples. This setup also gives you a sound base if you want more power in the future - just add a new turbo, and perhaps bigger injectors or a rising rate fuel regulator. If the car is close to 100,000km you will also need some cash for a new timing belt and water pump. Hope this helps. Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2742299 Share on other sites More sharing options...
Madaz Posted December 11, 2006 Share Posted December 11, 2006 go with 4door_sleeper powerFc first and foremost without that you wont be tunning very much fuel pump to give tuning more juice boost controller well for more boost then the rest as you see fit Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2742871 Share on other sites More sharing options...
Pauly33GTS-t Posted December 11, 2006 Author Share Posted December 11, 2006 Thanks for this guys, i will remember it, will follow this advice for any skyline i end up getting, either the one 2moro or if that doesnt work out, the stock one ill buy after christmas. Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2743221 Share on other sites More sharing options...
OZ_Pomy Posted December 12, 2006 Share Posted December 12, 2006 Insurance would be the first mod i would be doing if you werent planng on that. Apart from that the usual cold air intake clutch fuel pump intercooler exhaust boost controller aftermarket computer these arnt listed in any order but with the lot you should hopefully be around the 200 rwkw range Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2744576 Share on other sites More sharing options...
Cubes Posted December 16, 2006 Share Posted December 16, 2006 Thanks for this guys, i will remember it, will follow this advice for any skyline i end up getting, either the one 2moro or if that doesnt work out, the stock one ill buy after christmas. Thats the way SAZilla... Don't jump in to buying something if it doesn't 'feel right' Even though its so hard not too. Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2755144 Share on other sites More sharing options...
Madaz Posted December 16, 2006 Share Posted December 16, 2006 oh ever so hard not to jump in im a bad for that 1 bought my steering wheel for PC on a impulse Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2755174 Share on other sites More sharing options...
Pauly33GTS-t Posted December 17, 2006 Author Share Posted December 17, 2006 hey fellas im looking in autobahn catalogue here and its got Greddy FMIC kits for ~750-800 mark, if you guys have seen this one, you think its a good buy for quality? im tending to pick only good quality parts for my new car. i heard u can get FMIC kits for as low as a few hundred. Link to comment https://www.sau.com.au/forums/topic/146925-need-specialist-advice/#findComment-2755848 Share on other sites More sharing options...
