Just wondering if people who have one can let me know how great they are on the race track? dose it feel betta with more front wound on or strarts to get understeer?
Hi Race & Rally Repairs, I am the seller of this TSC. I know that there are at least a few people who have bought the unit that are using it for track racing who have indicated that it is great to be able to control how 'taily" the GTR is. If you wound it right up then yes it would tend to understeer but that is under your control as you can set it all the way from standard (set to "0") to maximum allowable front torque (setting "10"). Racing in the wet is another story with one buyer saying it was "worth its weight in gold" (his words, not mine).
If you are interested I can contact these buyers and see if they are happy for me to give you their contact details so you can ask them first hand.
Justin
ExtremeTSC:- how bout a group buy on here (SAU)??
Also how much wiring/ work to fit these controllers, do they cause any sort of 4WD faliure?
Cheers
G'day sky30,
they are very simple to fit requiring just 4 connections. No-one has ever had a problem fitting them even those who admit they have no expertise in the area. They come with very specific instructions.
There is no issue with 4WD failure as the 4WD system is designed to work up to 50/50 torque split. The TSC is just telling the vehicle to transfer drive to the front wheels sooner than normal. It only affects torque split when cornering(which is when you want it) so majority of the time it's not doing anytyhing the car wouldn't normally be doing.
Justin
ExtremeTSC - Please be aware you are not an approved Trader
You have been warned before about posting for sale items.
This includes quotes and any other advertising
Do so once more, you will loose your account. You have had enough warnings.
Thanks.
Thanks.
Sorry, I wasn't trying to step on any toes. Am I not even allowed to answer questions about the product? (not trying to be sarcastic, it is a serious question).
I am happy to become a trader but the difficulty is that when I requested to become one I was flat out refused by a moderator because I operate as a sole trader (which is a legitamate business structure where my full name is regarded as my business name) and don't have an "XYZ Performance" type business name. I was told by the moderator that until I get such an "XYZ Performance" business name I cannot post anything for sale whether privately or as a business. I am not yet at the stage with my business(which incidently encompasses other areas) that I am prepared to register such a name as the ATO has no problem with me trading freely.
If I have been given the wrong information then please let me know so I can move forward.
We are not as far as i can see from the Mod panel.
As for what you were advised, if that was from Blitz, then its final. We have strict rules to protect people as best we can.
If you did not hear this from Blitz. Please contact him as he is the person to talk too. No-one else.
Cheers.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
