  • Replies 87
Posted Images
Cheers Huddy.
I think i better talk to ryan and Terry pretty snappy.
I want the 23/24 so i can be different. But it seems like the 25de from the 32 is the way everyone is hinting for me to go.
Atleast the pricing from everyone is around the $5000 figure. I was thinking it would be different from workshop to workshop.
Just need to get to know the mechanic of choice for my engine swap so I dont get a brand new lemon.
Kansai is moving further away from me. Dam you TELLY
what about a 32 rb25de with forgies and upgrade valve springs
or 25det it 3.5k for a engine package you cant go wrong
shit take it to your mechanic comp test it leak down test it and if you dont want it
give it back and try again with one of the 2 other 25det we have in stock now
"u could do a rb30 for 3.5k
all depends what u want"
rb30 would be nice but he'd still have a auto rb30 4 door 32 unless he spent another $500 on a rb20 box which would blow behind a 30 sliding in about 2 min
so he'd have to buy a 25 box so add $1,500 to the rb30 idea brings you to 5k which is the whole budget
ps 3.5k 25 package all includes 25 manual box
Nothing wrong with an auto rb30. In fact hed have a faster car than u or i if he kept the auto...put an mv auto shift kit in it, and it will be as tough as your rb25det box.
Rb20 gearbox will last for a while too. Cubes ran his for over 12 months before it let go, now hes going auto as a matter of fact, so its in his favour to keep it in. Hell even im thinking of going auto.
U are speaking to the wrong person to argue about a 3lt :thumbsup:
Edited by Bl4cK32
240rwkw.. Sky30 went through I believe 6 or so rb20 box's. :S
I've just done another 12months on the replacement rb20 box and its going strong with no strange noises. The old rb20 box had a thrashing of 4 years in my hands and around 135,000km's (total ~200,000-210,000km's on the clock) so it was well used and not just drop rb30 in and bang.
I'd stick with the auto for now. The rb20 box wouldn't blow when 'sliding' my feeling is they would last longer as its not 'gripping'. Grip is what kills the box.
Shop around.. There's one place I know of here in Adelaide that sells rb25det box's for ~1100. cut, weld and re balance your tail shaft, mod the gearbox mount and u'll probably get away with an rb25 box in the car WITH a clutch for ~2k.
Or stick a full manual kit through the auto box and it might even be better for drifting considering the rb30's bulk torque and spooling ability. :P
OK I have done the unthinkable.
I have sourced out a new engine and a full conversion kit.
So next week my car will be getting de automatic and bring on the 5speed manual.
If anyone wants parts off my engine let me know. Im keeping the timing belt, waterpump, tensioner & Idler bearings and rocker cover gaskets.
The rest has to go. So what ever you want let me know and im sure u can get it for alot cheaper then half the ppl here are selling it. i dont need a engine out the back collecting rain water.
So if you want parts PM Or Ring me on 0439455399.
The Autobox is for sale too. Make an offer and I wont say no. It needs to go once the work has finished. Should be a week.
Brenton. Im making a for sale thread aswell.
20.
Need my car fixed asap and i couldnt blow off the deal I have recieved from the mechanics behind my house. The owner owns a 32 and has replaced engines and g/boxs many times.
Plus i get a full 3 month warranty on all parts they change. So i am not complaining.
Its booked in for tuesday night. So hopefully a weeks time and its back in my hands/ feet and i can actually enjoy my car for once in the last 2 months
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
