I was just wondering what peoples opinions were on the best street package turbo installation for a RB25DET. Im talking in terms of a quest for great response, a broad but sweet power band and not over-the-top power. Present your ideas and constructive criticism here for everyone to view.
Cheers,
Tom.
  • Replies 55
HKS GT2540 is what I want for my car bit later down the track which is meant to offer good power at decent revs and all round street performance. Depends how much power you are chasing.
Of course if you hi-flow a turbo to "pick your own" characteristics and build it to suit how you will end up driving.
What I'd like is a Garret GT28, A/R-.70 comp/.64 exh, it requires an adapter to bolt to the RB25 manifold but will make around 230rwkw with around 13-14psi and will spool up pretty close to the factory turbo. The GT30 will make more power but with some extra lag.
Hi b0neR, specs follow;
Hi GT28 = 320 bhp
HKS 2540 = 350 ps
GCG Stage hi flow RB25DET turbo 350 bhp
Based on personal experience I would go for the GCG hi flow, you get basically a new turbo (all the wearing bits are upgraded/replaced) plus there is an upgrade path. We find almost standard spool up, noting that we always tune cars with turbo upgrades not simply fit them.
Hope that helps
Hi guys, me thinks someone at Zoom and HPI have been reading the posts on this forum. There are acouple of articles in the latest issues that refer to questions and discussion we have been having lately. The 2540 versus 2530 is in issue 30 of HPI.
Maybe we should be charging royalty, how about it Martin and Ben?
Hi benm, new rrp follow
GT28 = 320 bhp = $2,200
HKS 2540 = 350 ps = $4,790
Hi flow RB25DET turbo 350 bhp = $2,000
As usual all prices are negotiable, so bargain with your local supplier.
Hope that helps
We (Canberra people) just got a GCG rep for the ACT region. Met he the other day and he seems like a good bloke and really knows his stuff.
I might have to have a chat to him when/if I get my turbo done.
SydneyKid - that price for the GCG highflow, was that with ball bearing or thrust bearing? I'm thinking thrust...
Cheers
J
Does anyone here have or know someone with a HKS GT Turbo installed on there RB25? I have also heard that the 3037 is not a bad choice if large power is still wanted, coupled with all the right parts under the hood would this be a viable setup for daily drving??
Hi T0nyGTSt , re "Sydneykid has something against the 2540". Hey, I'm not the only one, ask around. If you want another written opinion, have a read of HPI issue 30 (the current one).
Hi Jay95R33, it was a ball bearing hi flow.
Hi Works Auto, re "These turbo's are a proper performance turbo". Give me a brake, Trust T78/T88 would be considered "performance turbos" right? That's how Trust promote them, very heavily. Well they are basically a Mitsubishi Canter turbo with some minor aerodynamic mods. Don't believe the publicity machines, they just want your money.
Hope that helps
Hey, Martin and Ben maybe that's what you should do in a future issue of Zoom or HPI. Rip apart a mega cost turbo (Say HKS or Trust) and compare it to the same basic turbo from the original manufacturer (say Garrett or Mitsubishi). Then stick it on a car and run them up on the dyno. I'd like to see that.
I like that :) :uh-huh:
Basically a brand new ball bearing turbo that has been matched to the RB25det and can flow upto 350hp for $2000 !!
I'll be looking very closely at that when the time comes.
Just one last question SydneyKid (I promise :P ) - from your experieances, how effeicant are these highflows at around 13-14psi?
The thing that worries me about the HKS' and others, is that apparently they only start showing their balls at 16psi+
If I get a replacement, I wouldn't want to go higher than 14psi, but would want to get good flow at that level... Does that make sense !!! Basically I'd want to get the most power I can at 14psi with good/strong mid range power and if possible have it spool up close to the factory turbo.
Sort of like having your cake and eating it too :)
Cheers
J
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
