Hi all,
i have just done a custom air intake on my R32.
It make use of the space reserve for the stock intercooler.
Problem with this one is driving on highway when rainning.
The water mist created by the car in front always make the filter wet. Thinking of adding some grill to prevent too much mist entering.
Driving on normal road where water mist is not as bad seem no problem.
https://www.sau.com.au/forums/topic/14738-custom-air-intakepic-attached/
Sorry to tell u this but it would of been far better to leave the filter where it was a and then make a CAI to it.
Using ur theory on the water spraying into the filter. Well imagine if a small rock or many get into the filter, then into your engine. Bye bye engine.
The Pipe work is going down and also i dun have problem with stone. Further more most cone type filter have metal net protecting it.
Its the Mist that got spray out of the tires from the car in front. That might be bad. use vent to guide the wind away from the filter but into the box will solve the problem but where can i get such things? Maybe just put wire mess???
Putting the filter in the engine bay is the first choice but u get plenty of hot air from the RB engine. So putting it at inside the small air box will be prefer near 100% Outside Temp Air.
the air it will be sucking will be heaps cooler than in the engine bay, even compaired to ppl with partitions. but i would be so worried about things hitting the filter and as u say water.
im happy to duct the cold air up to mine. saves the stess.
Hi Lambo. Nice work. I actually did the very same thing with my '33 a few months ago, although I think I went to a bit more trouble than you. I have no problems with water mist, wet filter syndrome or rock/stone damage. Just fresh ocean breezes. Made from stainless steel 3 inch mandrel bend, welded to a stainless flange which matches the air-flow meter flange. It was then powder coated in a semi-gloss black to match the finish of the air-flow meter. After a quick "driving-in-the-rain", problem areas were shielded with thin rubber matts.
This set up works just as well if not better than CAI's (worked better than my CAI, which was a great setup in the first place) and it gets rid of the, in my opinion, yucky box in the corner of the engine bay.
Obviously this kind of thing isnt really necessary, but for people like me and Lambo, we like making shit, and being slightly different.
Here's my illustrated documentry i digged out of my PC.
Rock on Lambo... you're a genius! :)
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
