Hey all,
Just a quick question, does anyone know what day the HSV Owners club is going to PI this weekend, if there is one?? I vaguely remember there being sprints on this weekend, but I need confirmation. Pretty sure it was the 16th...
Cheers
Dane
https://www.sau.com.au/forums/topic/147438-hsv-sprints-at-pi/
Thanks guys.
I may be a touch confused, but I know that there was a HSV day on this month at some point at PI, so I'll keep digging.
I don't want to enter anything Bec, just want to take a look see :)
EDIT: Way off :devil: It was in October
Supp Regs, etc
I guess theres a possibility some people have pulled out.
Could always give them a call and see if you are interested.
Last time i spoke to Neil Choi there was 20 people of the waiting list :):P
Regards
Andrew
Yes, explain.
I've got one of the quietest GTRs around and I was flagged in the first session for noise. Apparently my car was 83db and the limit for the track was 75db.
Beno has tweaked some magic into the car. I was litterally just warming up and had traffic holding me up and I was completely surprised to see the 1.45 times. I'd say now that 1.43s or even better if I get brave are possible with the car the way it is.
I went out in the second session and got flagged instantly. Home time after that.
BUGGER !!!
Yes, explain.
BUGGER !!!
I got pinged for 81 at the MSCA day Aaron - the EPA guy goes after lunch so just short shift and wait till the arvo sessions.
Soooooo......how is the stroker kit :(
I have to ask, is still fun going that quick? It woudl scare the shit out of me. Top work
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
