after that maybe we can see who has got the biggest schlong.
maybe i will bring the volkswagen  out and kick ur ass.
so did u buy a new watch :)
You seriously wanna have a schlong contest?? Geez your brave :)
Yeah bring the volkswagen out so you can kick my arse, but I'll also bring my truck coz ur gonna sure as hell need it towed back to your workshop once were done :devfu:
Hey, why do I need a watch?? I'm always prompt aren't I?? :P:P
  • Replies 108
Hey, why do I need a watch?? I'm always prompt aren't I?? :(  :)
gee if im not mistaken, didnt u need a tow truck to get yours home, or did u drive with 1 turbo. :) .
do u know what prompt means.
Actually Dean, I drove it home from calder and on the weekend to my g/friends house and back, the turbo is not completely rooted, its just not making as much power when coming onto boost....
One day I'll be on time.... :D
Hey Rick,
What clutch have you got in your R, single or twin plate?
The reason I ask, is that I use to use a nismo single plate, was a good clutch for street traffic use but after some 4-5k launches it ended up slipping bad.
Now I use a OS giken twin plate that has been modified.
Its now a solid centre twin plate 12 puck clutch that is only either on or off which now makes the car bog down if launched under 5k or certain low rev gear changes (light-weight flywheel will be a contributing factor too) and it hasn't slip one bit so far.
As for traffic use, haven't stalled it yet.
But now I can go "12345678....side step clutch and change lanes with torque steer" :)
MEGA
i have a 'nicks performance clutches' clutch...after frying one 5 puck he did a better pressure plate setup for me and it hasn't slipped yet..i do the torque launch thing and its all good with down to 1.6 second launches...I have steel wheel turbo's and you can tell they punch good air as compared to other gtr's I've driven it goes harder...I am just dumbfounded on how to get 11's with pump fuel and street tyres...everyone else is...cam gears are next but still, i hear about these 11 second standard turb gtr's but are they runnin avgas or somethin cos I ain't gettin there with hifloed turbs.
  • 4 years later...
What would my R34 GTR V Spec run the 1/4 mile in???
It has:
* HKS front pipe
* HKS cat back Hi Power system
* HKS pods
* HKS EVC
* Nismo Fuel Pump
* Nismo Fuel Pressure Regulator
- Stock Everything else
Pulled 242 AWKW @ 1.2Bar
[email protected] 34GTR V-spec II boost was 1 bar car has 260awkw,mph was up their for 11sec just lost time off the start, 60ft was 1.98 so pretty slow start put this down to stock suspension car would squat down at the rear have now fitted a set of HKS hipermax II coilovers , was only able to run twice as i destroyed the single plate clutch the same night it seemed to hook up ok for that run so i dont think it was much of an issue now have a nismo twin plate so with the clutch and coilovers will see if it hooks up any better . also had a custom stainlees exhaust that looked a bit dodgy after we removed it to fit a Veilside titanium exhaust that weighs 4kg also will fit a ACPT carbon one peice prop shaft when it arrives and will take it out to the track again hope to run in the mid to high 11sec
Edited by gtr13
Previous Standard R32 GTR
stock turbos
10psi boost
cat-back exhaust
exedy twin-plate
12.506 109mph
Current R32 GTR
internal work done
HKS 2540 turbos
290kw at all four 17psi boost (tuned for response not outright power, injectors started to max out)
1.6 60ft
11.4 118mph
my 60 foots were 1.7s top speed was 181kmh....
i tryed a 7000rpm dump and held it flat but it only spun all fours for 1st gear 60foot of 2.0 lol
i think ill get some semi slicks for the rear next time :rofl:
thoughts ideas?
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
