There are a few differences, one being the sensor plugs on r32 are round, square on a31. Also the r32 engine has a little more power in stock form. The r32 has factory bov and a31 doesn't. I have heard there is more potential for higher power outputs from the a31 engine, not exactly sure how or why though. Not sure on if the turbos are the same
Edited by Love_Hate
The cefiro inlet cam has a longer duration and the exhaust cam is retarded about 2 deg from the R32 cam.
ceff afm, coilpacks and ignitor are different.
ECU also only has 1 fuel map and 1 timing map as opposed to the skyline. it has 2 fuel and 2 timing maps.
If you look at the 2 maps the skyline runs 3 deg more timing and has different load tp scaling.
thanks for all the replys so with these spitfire plugs can u get spitfire coils that u can just plug in to replace the stock coil packs over coil pack problems?
They are adapters. http://www.skylinesaustralia.com/forums/in...mp;hl=splitfire Seems Splitfire didn't want to manufacture different coilpacks for the same engine. If you could get hold of a R32 coil pack loom and are 1/2 handy with electrics you could easily knock some up yourself.
so that is only for the adaptors then u would have to get ur hands on some 32 coilpacks to plug in them or do u buy the aftermarket ones as shown on the pics below the adapters ?
the turbo is different also, R32 is ball bearing ceffy is plain bearing. also slight differences in the exhaust side.
later ceffys run the rounder R32 style loom plugs, but most are early ones
AFM, coils, CAS and some other sensors are the same as R31 Redtop RB20DET. turbo is also the same as that of a redtop.
loom (bar the plugs), injectors, head is all the same as r32.
while working on my dad's cef (series 1) I found that it had more parts in common mechanically (well, engine and electrics) with the R31 GTSR than it did with the R32 GTSt.
  • 4 months later...
i just found out that my R32 RB20DET engine is being run off a cefiro ECU...
can anyone tell me if this is dangerous for the engine?
i'm trying to track down an R32 ECU, but having no luck so far...
if anyone can help me by answering that question, it would be GREATLY appreciated... :D
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
