How about some constructive comments guys? Just tell him what you think it's worth, not whether you like it or not.
sorry paul, i missed the part where u became a moderator?
or how about this
any opinions ???
i believe by saying that he is in fact asking for our opinion on whether we like it or not....
werd adam32!
.. anyway, I reckon there'd be also some price difference between the series1.5 and older series1's.... ie the 1995 onwards came with the same s2 wing, engine differences (igniter on each plug) driver airbag, that kinda stuff.
So a series1.5 could fetch around what a series2 is also...
revised
96/99' SKYLINE GTS R33 TURBO
MANUAL TRANSMISSION
GTR STYLE TOMMI KAIRA BODY KIT
55000 kms
RECARCO 2000 RACING SEAT
GREEDY TURBO TIMER
BLITZ TURBO METER / OIL PRESSURE
BLITZ BOV
ORC BIG SINGLE CLUTCH
BLITZ LM INTERCOOLER
HKS HIPER
PROJECT U" BRAKE DISC AND PAD
17" JAPAN WHEEL / S02 TYRE
KENWOOD CD PLAYER
new info :
290Hp, GTR Key (start engine)
96/99' <--- it is surely built in 96 ser 1, 99 first license
first at all, thanks for everybody reply my post, even some body said that's a crap/ugly car. that's my pleasure. coz i m a fresh man in this forum, i will spend more time in this forum to know more about skyline
Originally posted by franky
revised
Firstly there is no way it was built in 1996 as even late 1995 series 1's had airbags.
Secondly I see no way that a car would sit for upto 5-6 years before being licensed.
Sounds like a con to me so I'd avoid it like the plauge as there are plenty of other 'lines out there to choose from
Cheers
Chris
actually, this is not my car, i m thinkin to import it, but i really wanna know how much it worth first, obviously, if it doesnt worth for the importing cost, i will buy one from local dealer. u know
this is because the car in my hometown, so very low km and first license in 99.
i have no idea why it is ser 1 built in 96, but the owner can prove it. maybe someone call ser 1.5.
franky - i'd be very careful about this one. it sounds like someone may not be telling you the truth about the car. i've got a 95 series 1 and it has an airbag.. though maybe someone has replaced the airbag steering wheel with a non-airbag one?
looks nice though.. :P
looks nice yeah nice wing like yours cam lol
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
