  • Replies 6k
Posted Images
thanks mate ill keep that in mind. Ive got a couple of spare 18" tyres for track, if someone actually organises a track day!, at the back that i may have stretched onto the rears.
Yeh get em streached, you can check mine on Sunday see what you think! Yeh track day sounds like a plan, thinking i'm gonna be doing some Modern Regularity out at mallala soon and some practice days.
Ask him.. urself..
but he's got a point.. SR power to weight ratio is pretty awesome..but still it ain't a skyline..
I would take my RB over SR anyday. Im only talking from what i know. I dont know if the redtop is different to the other generation SR20's but my brothers sounds like a friggn mack truck and its soo lound in the cabin although it would eat me in a run. :hellpisd:
yeah mate i think he did not only that hes got a hc with it plus injectors if im not mistaken. I dont know why the injectors though without aftermarket turbs. All from nengun if i remember correctly.
Fark!!! he spent some money then, hay?
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
