Can any of you guys educated me (aka NooB ) on turbo's? like what the hell does all the number means ?.. e.g. hks gt25/30? gt25/40 and then there are turbo's out there t66? t88? t70? man.. I just wanna do some research for later upgrades.. but getting no where?..
Another question? .. will twin turbos fit on single turbo? ( silly question eh?)
If so anyone interested in goin halves on a pair of HKS GT2530 for $1500?
ebay link..after currency conversion + delivery $3000
  • Replies 6k
Posted Images
Yeah neither would I for that price...
Damn cheap if you ask me..
depends on the actual condition though..
What you could do is fly up there... drive it back lol
then drive to whyalla and get it registered under my address here.. u dun have to worry about regency if you do it that way.. ;)
other wise if they put you over the pits.. ur F$@% ed with that beast..lol
I picked up a line from Brisbain a few week ago and drove it back. It had lots of rice and wouldnt get through Regency. I took it to the Sturt DMV and they did the checks and let me go. They were nice guys, picked up that my tint was too dark, but didnt make me remove it. Didnt worry about SAFC, RPM, Turbo timer, Bleed Valves etc.
Yeh oi Sturt is the way to go, much better down there, especially if the car is just registered in another state, they just check the numbers and the obviouse things and away you go!! :uh-huh:
The 34 left Nagoya Friday week ago, so should be here in the next 2-4 weeks, depending on shipping transfers, wharfies, customs procedures etc .... then I have to stock it out for compliance, they keep it for 2 weeks compliancing it, then it will be on the road. So my S15 goes in and gets some mechanical things perfected tomorrow, then gets a new clutch, then I will put it on the market. I hope to sell it before my 34 is on the road, as I don't have the garage space for both of them!
i have space in my garage for any one of your cars andrew. :uh-huh:
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
